Looking for low cost high Xmax 6" woofer
Old 25th July 2011, 03:39 PM   #1
thoriated is offline thoriated  United States
Default Looking for low cost high Xmax 6" woofer
Hi -
Does anybody know of a low cost higher Xmax (at least 4-6 mm peak and Xdamage of 12mm or better) 6" woofer with a reasonably robust power rating? It doesn't have to have a particularly low Fs or fancy basket. Anything between 45-80 hz is fine. Paper or plastic or metal cone is fine - paper, cloth or rubber surround ok also, but I don't want to use a driver with a foam surround.
This is for a special project where I need a number of these drivers (up to 20) (has some relationship to my HT speakers that I posted about), so I want to keep the cost down as much as possible.
I'm looking for something substantially cheaper than some of the Tang Band long throw drivers which would otherwise be suitable choices.
Thanks in advance for any assistance!
Old 25th July 2011, 03:46 PM   #2
DrDyna is offline DrDyna  United States
DrDyna's Avatar
How about these?
DIYCable.com : Intro Home Exodus Anarchy
Also these, a bit cheaper.
http://www.madisoundspeakerstore.com...y-cone-woofer/
Old 25th July 2011, 03:59 PM   #3
R.I.P.
Aurasound NS6-255-8A Paper Cone Woofer - 8 ohm: Madisound Speaker Store
The above has good excursion but likely a "soft" BL curve, i.e. distortion
is not low and then suddenly increases massively if you exceed linear
excursion, more likely there is no clear excursion limit point.
Its a short coil big gap design.
Klippel discuss the issues in the distortion paper on their site.
rgds, sreten.
This probably also has decent excursion of the long coil short gap variety :
Peerless 830307 6.5" 4 ohm: Madisound Speaker Store
Old 25th July 2011, 08:42 PM   #4
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
What about this one:
GDN-17-200-8-SW - Kino domowe, g?o?niki, kolumny - STX polski producent
Think I'll try these one of these days ... at that price it's hard to be disapointed I guess
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 25th July 2011, 09:35 PM   #5
CharlieLaub is offline CharlieLaub  United States
Default Silver Flute W17
The Silver Flute W17 is a good bang-for-the-buck driver and has 5mm Xmax. Madisound sells three versions, starting at under $30 each:
W17RC38 at Madisound
You really should not be asking about Xdamage regarding a 6" woofer! Save that for your subs.
-Charlie
Old 25th July 2011, 11:04 PM   #6
Thanks for the excellent suggestions. I will be looking more closely at at least two of them.
I don't intend to push whichever I use to Xdamage - I was asking because some long excursion speakers I've seen (and own, not my Aurasound NS3 knockoffs, btw, which have a healthy amount of excursion beyond Xmax) seem to have Xdamage not very much higher than Xmax.
Old 26th July 2011, 12:18 PM   #7
DrDyna's Avatar
From a pure xmax point, I don't think you can do much better than the exodus anarchy. They are kinda pricey though if you had to buy a lot of them.
Old 27th July 2011, 01:48 AM   #8
PeteMcK is offline PeteMcK
SEAS ER18RNX, not the cheapest probably, but certainly the best quality /$
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 27th July 2011, 02:57 AM   #9
scott17 is offline scott17
The P17WJ00 formerly manufactured by Vifa is a very fine driver used in many designs. Perfect Qts for a 4th order Butterworth. Maybe some folks aren't aware that this is still available.
ScanSpeak Classic P17WJ00 6.5" Woofer: Madisound Speaker Store
Looking for low cost high Xmax 6" wooferHide this!Advertise here!
Woofer "Speed," high Xmax vs. low Xmax in Uframe and Sealed Enclosures jarvissound Subwoofers 35 21st March 2014 10:48 PM
High Cost/Performance value 8" woofer kevinlin1013 Multi-Way 24 13th January 2011 05:50 AM
What is the most durable 8" high xmax woofer? sardonx Multi-Way 14 24th July 2005 07:18 PM
12" driver with big Xmax,low Fs, & high efficiency? WolfmanX Multi-Way 18 26th November 2002 11:10 PM
Copyright ©1999-2017 diyAudio
