Old 25th July 2011, 01:24 PM   #1
Default MTM good idea with these drivers?
I have 4 x aurasound NS6 midwoofers (8 ohm) and pair of 6.5" MCM waveguides and selenium comp. drivers sitting idle and was thinking of putting together a highish efficiency speaker for the TV room (around 90db). My question is would a MTM be feasible considering the higher CTC spacing with a waveguide? I wouldnt think the selenium would be comfortable crossing lower than 2k in this waveguide and i'm wary of comb filtering, though ive never built an MTM so dont know how problematic it would be in reality
It would be nice to get the MTM benefit of minimised floor and ceiling reflections but don't want to push if it will cause more problems elsewhere. Would a 2.5 way be a better choice here?
Old 14th August 2011, 12:26 PM   #2
Default Go Modular
Put each driver in its own enclosure.
Then you can arrange as you like for a particular venue.
WHG
Old 14th August 2011, 12:48 PM   #3
Ha! Good idea and would look cute too = +1 WAF points
Old 14th August 2011, 02:42 PM   #4
AllenB is offline AllenB  Australia
For a successful MTM, time alignment becomes important. Not easy with a waveguide.
Old 19th August 2011, 11:32 AM   #5
Hi Allen, I was planning on using miniDSP so can delay the drivers. However I might take this project in another direction anyway.....
Old 19th August 2011, 11:58 AM   #6
What is the main benefit of MTM anyway? Vertical dispersion? A good thing, for sure, but there are other and more important things out there. Good luck with what you're going to do instead.
Old 19th August 2011, 12:14 PM   #7
Yes and of course higher efficiency over regular 2-way. I think 2.5 way would be the better option here anyway. I may still have a crack at the MTM with a dome tweeter sometime in the future.
Old 19th August 2011, 12:22 PM   #8
If you are considering 2.5 way, there's one thing I'd like to add. Your 0.5 way cuts in and adds more total energy to the room, when only the on axis response is at issue. No matter what you do with the 0.5 way, your baffle width will have it's effect on your room. Have you ever built a wide baffled closed system?
Old 21st August 2011, 02:51 AM   #9
I think MTM are pure BS....We recording engineers and sound engineers never use them...
You are getting different arrival times from the drivers in anything but the sweetest of sweet spots...bluring the image the artist and engineers intended for you to hear....you are no longer reproducing music with an MTM but creating it....you are coloring the sound like all those horrible Bose products out there. I am not sure where Dickinson came up with the idea that there were going to be cancellations at the ceiling and floor....that is impossible to predict and control, it is just theory that somewhere at sometime it will happens....room reflections are accounted for when we recording engineers reverb our songs....we use less as we know your room is going to be live....so we mix in a dead room to hear and control the true sound out of our monitors and rough in some reverb but we do final reverb in a live room..... Death to the MTM !!!! so says this recording engineer....
Think of how many comercial products you see using MTM ...virtually none, even wilson watt stopped doing it and you will never see a pro speaker built as an MTM.... we does use arrays for shear volume in an outdoor live situation ....and they sound pretty crappy but the are loud. . . .
Old 21st August 2011, 12:22 PM   #10
I guess MTM and 2.5 way are both compromised solutions to the same problem - increasing efficiency of a small driver. When you need a small footprint and narrow baffle its only way get the job done.
Has anyone modeled this MTM idea mcmahon48 Multi-Way 2 18th May 2010 11:40 PM
a bass reflex using two fullrange drivers. A good idea ? hornophile Full Range 10 27th January 2009 11:50 PM
Page generated in 0.11446 seconds (81.00% PHP - 19.00% MySQL) with 10 queries
