Please have a look at the image below , I want to know where the test mic is placed from the driver (1m away). Is it location 'A' or 'B' open field (outdoor) test. ![]() ---------- Below is a driver specification (freq response) from a chinese company , on the LHS the dB scale is written as 0~ 25dB , is this reading at 1Wrms applied to speaker.I just want to know what type of graph / specification is this from more experienced members. ![]() Thanks for your time. |
#2 |
I would choose B as the measuring position, 1 or even 2 meter away for the on-axis performance.
You can move the mic in arc (same distance from the end of the horn's center) at 7.5°*intervals if you want to get off axis response (horizontal and vertical). The driver should be mounted in its intended baffle first. The dB scale on the plot must be arbitrary or relative. Any driver that only produces 20 dB at 1 Watt probably has a rat stuffed in its throat. |
#3 | |
#4 |
"Which is correct A or B" is an interesting question, as it is a bit arbitrary. I would tend to agree with B but there is a case for either. B is 6dB less because it is twice as far away as A. It would be more accurate to move farther, say 2 or 4 meters, and then correct for distance (add 6 or add 12 respectively). I believe measuring from the horn mouth is more conventional.
The graph is uncalibrated. The 0 to 25 scale is just the scale that came with the graph paper (looks like a copy of old B&K strip charts). They should have given a calibration reference such as: "0dB equals 90dB for 2.83 volts at 1 meter". Regards, David S. |
| Polar Measurement setup | thadman | Multi-Way | 7 | 7th June 2009 06:29 PM |
| Help choosing measurement and modelling setup | SimontY | Multi-Way | 65 | 26th April 2007 05:05 PM |
| Inexpensive Double Mic Setup For Low Frequency BR, TL Measurement | kelticwizard | Multi-Way | 4 | 5th July 2006 11:36 PM |
| Graph shapes | Danielb | Multi-Way | 9 | 3rd November 2004 12:26 AM |
| What graph to look at? | pjacobi | Solid State | 3 | 18th February 2004 01:56 AM |
| Page generated in 0.07193 seconds (74.54% PHP - 25.46% MySQL) with 10 queries |
