#21 | |
SpeakerDave: yes, thanks, some credibility. Experience helps, experience and a fairly unlimited budget helps even more.
So the question becomes about the tweeter(s) again: what kind of harm does having a smaller tweeter array inside the woofer array create? Also, what does making an "expanded D'Appolito" array make (putting the tweeter in the center of the stack)? My plan would probably be for full floor-to-ceiling. Quote:
#22 | ||
BTW, I'm fully aware of what comb filtering sounds like; I had installed those cheap Technics round "ribbon" tweeters in some old Onkyo towers. They overall were a big improvement in imaging, flatness, FR, etc, but created some NASTY comb filtering effects that could be heart easily by plugging one ear, turning the other towards the speaker, and moving side to side (relative to the speaker) even only an inch or two. Dispersion was horrible. I did wonder if a line of those would create a more even field since they may fill each other's voids. |
#23 | |
The EQ requires a 3dB shelf at about 6Khz (above which the 3" drivers have very little response and without the complex wiring, would require a much higher shelf), a cut at the -6dB notch frequency of the open baffle - though you'll notice the baffle is shaped to spread that frequency around a bit and make it easier to EQ, and a bit of tweaking to make the bass merge properly. My biggest issue is the very bad phase shift at the main crossover frequency of 330Hz given the orientation difference between the side-firing woofer and the upper bit of the speaker, obviously EQ is not the answer here but the speakers are 1000 miles away from where I live now so it can wait. |
#24 | ||
Patrick Bateman discussed one of them here: D'Appolito Arrays with Waveguides Regards, David |
#25 |
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
I couldn’t decide if I should post this earlier in the thread but it’s Friday so what the heck. While this fits your title requirements, I am not sure it is what you want to build.
On the other hand, there is something nearly hypnotic (or possibly narcotic) about this video. Put headphones on and enjoy this multi-part line array “how to video”. ‪Linear Array - Line Array - Fake Bose L1 PAS Part 1 of 6 ‬‏ - YouTube
Bring back mst3k and futurama |
#26 | |
LOVE it, Tom! After viewing that, I'm feeling much better about my Sony 5" Neo woofers and the Audax/JBL tweeter line arrays. They stand about 6 foot, two inches tall but at least I used 3/4" ply and a proper tweeter line/XO packed in tight. Since I don't have two 12" subwoofers with a "pipe" in them--I'll go with a proper tapped horn. I'm feeling positively exotic to use a Roto-Zip these days. Thank you for the info, Speaker Dave--I've read about quite a few different designs be they shaded or full output; I went full output so I can stack them mono for guitar or vocals. Good to hear that 6 plus footers should not be shaded. Just something to mess around with in the garage, I might learn something and education costs money. August project is learn Horn Response and build a single 10" tapped horn in an attempt to match the SPLs of the garage arrays. House paint to match then invite BarryV over so we can imbibe with a few barley pops, play some tunes, eat some BBQ and laugh at my "craftsmanship". |
#27 | |
Rebel Samurai!
#28 | |
Linear Array - Line Array - Fake Bose L1 PAS Part 6 of 6 Last edited by MartinQ; 23rd July 2011 at 07:53 PM. |
#29 |
By price, I'm thinking about using one sensitive tweeter in the middle.
SpeakerDave: I think that I'm likely missing most of the subtlety here, so I'm curious how one picks a waveguide for this application. I'm sure I'm way off "ideal" here, but here's what I've been looking at: http://www.eminence.com/pdf/APT80.pdf - $30 at PE Eminence ASD1001 1" HF Titanium Horn Driver 1-3/8"-18 TPI along with Eminence BH410 1" Exponential Horn 1-3/8"-18 TPI or Dayton Audio H07E 6" x 6" Elliptical Waveguide 1" Threaded Seems like close spacing is priority #1 in this case, but the small Eminence horn won't cross over as low as I'd like, and the larger Eminence horn is more of a horn than a waveguide. The Dayton seems well recommended, but is large, and the 4.5"x4.5" has a high x-over point as well. Any recommendations? I know I'm shortcutting a lot of science here, but for one, I can't get that Eminence line array designer to work because I have Win 7 64-bit. Keep in mind that I'll be digitally EQing the hell out of this, so as long as the driver is clean/low distortion, I'm not worried about patchy FR issues. |
#30 |
Looks like not said yet, but if you use a single tweeter in the middle of an array of other drivers, you gonna have a problem as the level of a single source (the tweeter) decays twice faster than the level of a line source (the other drivers) according to the listening distance.
In clear, this means that the relative levels will be matched only at a specific distance : too close = too much treble, too far = not enough. Now, if you always listen from the same place it's less an issue as it could be in PA. Hence the recommandation of an array of tweeters vs a single unit, could it be a compression, that will also extend dramatically the power handling of the whole system, one of the big advantages of an array...my 2 cents. |
| Cheap, Fun line array candidate? | pjanda1 | Full Range | 2 | 18th November 2009 04:22 AM |
| advice needed for cheap line array tweeter | zobsky | Multi-Way | 23 | 15th September 2009 04:24 PM |
| Can you say the new cheap line array boner is here? | Feandil | Multi-Way | 0 | 21st April 2005 10:28 PM |
| Playing with cheap line array is fun! | JinMTVT | Multi-Way | 18 | 25th September 2004 08:27 PM |
| Open Baffle Line Array - using cheap drivers | giambi77 | Multi-Way | 4 | 26th January 2004 09:29 PM |
| Page generated in 0.12936 seconds (90.62% PHP - 9.38% MySQL) with 11 queries |
