Old 21st July 2011, 03:20 AM   #1
Moondog55's Avatar
Default Plessy midrange by Foster
Just picked these up as I thought they were the correct midrange for a mates rebuild, now I'm not so sure as he hasn't given me the original boxes and I am totally in the dark as to whether the old boxes are Sansui or something else.
Would anyone have the approximate parameters for these little 130mm wide flange integrated enclosure midrange drivers??
Black surround white paper cone and a black plastic compartment 120mmDia * 120mm deep
Only marking on the back are Plessey by Foster' Japan
130M08
8R 20 watt
and down the bottom 0648
Actually all I really need is the approximate Fs to work out if they will work in the original XO when I get the boxes.
Sound OK, quite loud and a little bright when played full range
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 21st July 2011, 03:24 AM   #2
Moondog55's Avatar
Pictures disappeared here they are
Old 21st July 2011, 09:00 PM   #3
Moondog55's Avatar
The very hard flat dust cap reminds me of another driver range, Bump??
Old 22nd July 2011, 01:32 AM   #4
Hi, surely the impedance peak is easy to measure for Fs / Fb ?, rgds, sreten.
I'd hazard a guess its relatively low, as the chamber is relatively large for
such types and probably far lower than an enclosed type if original fitted.
(Enclosed = sealed frame, no seperate enclosure, the most common.)
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 22nd July 2011, 01:40 AM   #5
Moondog55's Avatar
Sreten you are right as almost always but I have lost all my stuff in the pile of renovation rubbish and building materials, I can't even find my multimeter at the moment.
SWMBOs bathroom takes precedence over speakers.
I'd be happy with anything lower than 200Hz, but I think the very stiff surround means it may be a bit higher.
Still haven't got the boxes I promised to look at, these may drop in they may need work, but it is a swap for building work so they need to be a little better tan just OK when finished
Old 22nd July 2011, 02:01 AM   #6
Hmmm......
The separate cup looks quite deep to me, I'd say Fb is likely < 200Hz.
Maybe Vcup is a lot bigger than Vas if the driver has stiff suspension,
but then the question is why the depth / volume of the cup ?
Will you get the original mid drivers (bust or not) ? Cone
tapping should quickly illustrate the relative Fs's or Fb's.
rgds, sreten.
Old 22nd July 2011, 03:14 AM   #7
Moondog55's Avatar
Maybe, I certainly hope so.
Although the last pair of "broken and useless s*** " speakers I was given were fixed in 30 seconds with a soldering iron and sounded quite good when a little poly was added to the box. At the moment I don't even know if the woofers are 12 or 15 all I know is that they are ::"HUGE" :: which in todays world of mini surround systems means anything larger than about 6inches
Old 22nd July 2011, 03:15 AM   #8
Moondog55's Avatar
Volume is 1'3 liters which is as you say reasonable
Old 22nd July 2011, 05:11 AM   #9
Hi Moondog, IIRC, the Foster units were part of Plessy's last stand before they dissappeared from downunder; perhaps a search of old EA mags (~ late 70's?) if you can track them down in a local library may have a project that used these units?? (Sounds like you're a bit busy for that though... :-)
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 22nd July 2011, 07:14 AM   #10
Moondog55's Avatar
G'Day Pete
Only said yes to the rebuild because the mate is a carpenter and he will reciprocate in kind.
foster 035M1301 cone head Multi-Way 0 19th November 2010 07:52 AM
Foster FE103A rca9449 Full Range 18 29th April 2008 05:59 PM
Foster Tweeter ttan98 Multi-Way 2 8th December 2007 11:30 AM
Neofone and Foster _henry_ Full Range 20 8th February 2007 05:34 AM
Foster 100K03 tuberider Full Range 0 27th September 2005 11:47 AM
Page generated in 0.10849 seconds (81.20% PHP - 18.80% MySQL) with 11 queries
