I'm in BC, Canada and can't find a supplier. Even Windsor Plywood can't get it!
Where can I get my hands on two 4X8 sheets? Thanks for any ideas! |
#2 |
frugal-phile(tm)
We eschew the use of MDF, so haven't really looked into sourcing it. Chris has said he can get 1, or thicker on special order.
I'd just look to use 18mm Baltic Birch. All round about the same stiffness, but better damped, stonger (and lighter) than 1 1/4" MDF. You can get that at Windsor. Barring ply, you'd likely be better off laminating 1/2 or 3/4" Particle board to 1/2" MDF. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I want to build Onken cabinets. I have thought of laminating but I don't think I want to spend the extra time.
Thanks Dave, I'll look into the Baltic Birch. Brian |
#4 |
one of my main plywood suppliers is out of canada Locations & Contacts they have it down here .
however i hate using mdf for anything and i'm a cabinetmaker . cheers Woody |
#5 |
I just called my local Windsor Plywood store and they now have it!
They forgot to call me I like to use it for the low cost aspect. Thanks for all the help guys! |
#6 |
In NZ we can easily get 3, 4.5, 9, 12, 18, 25 (1") and 30mm MDF.
Mind you, we do make an awful lot of it ;-) |
| MDF and "particle board" | jmar | Multi-Way | 19 | 20th October 2009 05:15 PM |
| Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF | 454Casull | Multi-Way | 0 | 18th November 2008 02:19 AM |
| How do you "edge seal" your MDF enclosures? | The Paulinator | Multi-Way | 22 | 10th October 2007 02:38 AM |
| birch vynil veneer sorce needed | mightyjimbo | Multi-Way | 1 | 28th March 2004 07:20 AM |
| Page generated in 0.07347 seconds (74.99% PHP - 25.01% MySQL) with 10 queries |
