A source of cheap/decent high value inductors in europe?
Old 18th July 2011, 05:56 PM   #1
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Default A source of cheap/decent high value inductors in europe?
Shocked at the pricesDoing a 1.5 way build so its not high power- can't afford much.
Need values between 8-10 mH..looked on ebay, zero Any recommendations for good quality at a reasonable price?
Old 18th July 2011, 06:25 PM   #2
crazyhub is offline crazyhub  France
Default coils choice
Coils values - 4.71 - 10.0mH - Europe Audio
Coils values - 10.1 - 47.0mH - Europe Audio
crazyhub
Old 18th July 2011, 06:32 PM   #3
fatmarley is offline fatmarley  England
Crossover Components - Inductors
http://www.hificollective.co.uk/comp...inductors.html
http://www.wilmslow-audio.co.uk/inductors-70-c.asp
Old 18th July 2011, 09:19 PM   #4
Thanks for the links, the Monacor coils look good value and also air core inductors direct from Erse in the states (might get away without customs charge) I will keep looking and will post on here if I find anything else
btw Blue Aran - Professional Sound and Lighting sells monacor stuff and is often much cheaper than other online shops- they don't do the values I want tho
Old 18th July 2011, 10:45 PM   #5
Bill, I don't know how many money you want to spend but the Ferrobar line of IT coils are the very best quality/DCR ratio I know of:
DR56/10/140 - FERROBAR coil 10.0 MH R0.371 DR 56/61 CU=1.40 AL 40 MM - Europe Audio
crazyhub
Old 18th July 2011, 10:56 PM   #6
Thanks crazyhub - I want to spend about 30 gbp for 2 if possible
I have no idea if it is possible to use these as inductors - enamelled silver plated copper wire 1.2mm bobbins 10 metres for 7 quid Silver-plated Cu wire 1.2 mm - Enamelled copper wires - Conrad Electronic
also some craft bobbins like this on ebay V cheap
Old 18th July 2011, 11:11 PM   #7
IMHO yes if "enamelled" means "electrically insulated" but I don't know if 10 meters are enough for such values, in any case on air core.
crazyhub
Old 18th July 2011, 11:27 PM   #8
yes it wouldnt be long enough for a 10 mH value but I thought it might be of interest to some ..if it works.
Old 18th July 2011, 11:31 PM   #9
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
So many reasons to go for active filtering! With copper prices going through the roof there is just one more incentive.
But from now on I will be discrete about it.
Old 20th July 2011, 07:09 PM   #10
Probably go for the jantzen air cores - they seem good value
A source of cheap/decent high value inductors in europe?Hide this!Advertise here!
cheap sub driver in europe.. needmorstuff Subwoofers 3 19th September 2008 10:00 PM
Europe cheap capacitor ????where TJ Parts 17 22nd September 2006 08:52 AM
Good Source for high current Inductors?? Zero Cool Pass Labs 5 14th November 2004 12:36 AM
Hammond 125ese cheap in Europe? John007 Tubes / Valves 10 4th March 2004 09:18 PM
cheap subwoofer in europe then_dude Subwoofers 2 1st March 2004 08:06 PM
Copyright ©1999-2017 diyAudio
