I´m going to build a new center speaker with a 1,5" horn and 2 x 10" speakers. Am i getting trouble with a laying MTM ? Or should i mount the horn above the 10" like this Jbl center: JBL SYNTHESIS - Product Details
Crossover freq is 750hz. mats
James B Lansing= Nr 1 |
#2 |
Any ?
mats
#3 |
MTM if you don't have constrains dimensions
#4 |
I'd be worried about horizontal lobing and try to mount the tweeter above the woofers.
How many people will be listening to this?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#5 | |
DIY Centre Speaker advice b Last edited by bjorno; 18th July 2011 at 10:17 AM. Reason: Lost posted text due to 'site maintenance'? |
#6 |
How many persons ? One or 2 .
mats
#7 |
I would watch the Center to center distance but at 750Hz you certainly have more room. How wide is your horn?? Clasic MTM is distance equals 1/2 wavelength at crossovers. I use the Array 880 as the center in my HT set-up, even though it's an MTM it sounds very smooth off axis. You can't hear any obvious lobing issues. It also has the horn vertical though and that helps minimze the C to C distance. The woofers are twin 8"s.
"I could be arguing in my spare time" Last edited by Robh3606; 18th July 2011 at 02:42 PM. |
#8 |
My horn is 520 mm wide.
mats
#9 |
Well with a 20" horn and another 10" at the least for C to C I would definately drop them under the horn. Wavelength is only 18" ay 750 hz. You would want 9" C to C you are not going to make that with the horn in the center. What are you using the 9800 horn clone?
Rob
"I could be arguing in my spare time" |
#10 |
A Tad Th-4003 with 2 Tad tl-1102. I have the 9800 clone in another setup.
mats
| Need opinions for a TA2020 multimedia build. | cadakus | Parts | 0 | 10th June 2011 08:09 PM |
| Wanting opinions on first OB build | happyb | Multi-Way | 8 | 21st September 2009 12:21 PM |
| Looking to build an in-wall center speaker. | Newbomb | Multi-Way | 0 | 9th July 2009 04:47 AM |
| Build a center from single floorstander parts? | calbear81 | Multi-Way | 3 | 24th September 2008 09:49 AM |
| Page generated in 0.09271 seconds (78.07% PHP - 21.93% MySQL) with 11 queries |
