Old 16th July 2011, 10:35 PM   #1
Default PMC clones
Hi everyone, my first post and already I'm trying to pick brains..
Building a PMC TB2 clone and looking for any info on them, seems there are some pics about TB1 online but nothing about TB2 (I'm talking about open cab pics)..
Anyone got cab schematics? I know it's a long shot..
Will be using different drivers than the TB2 and a different designed from scratch crossover so they are not exactly clones, but I am trying to replicate the cab detail as much as possible so in future I can pop in some Vifa's and see if it changes anything
Cheers!
Old 17th July 2011, 03:10 AM   #2
AllenB is offline AllenB  Australia
Here are some naked cab pics, and some driver pics, and a similar (smaller) PMC DIY project
Old 17th July 2011, 03:26 AM   #3
Default clonez
The guy building the TB1 clone is not taking in account the thickness of internal bracing panels.. they are thinner than the walls.
I also think (judging from photos on the net) that they are actually plywood, and walls made from MDF. There must be a reason behind this... I will try to include such details in my design.
Old 17th July 2011, 09:20 AM   #4
burnett is offline burnett  Germany
The internal bracings are only 10mm MDF (everything else is 19mm).
Inside Pictures
Old 17th July 2011, 12:26 PM   #5
DrDyna is offline DrDyna  United States
DrDyna's Avatar
That TB2i looks like a good little speaker to copy, but if you're going to make the cabinet dimensions the same and the length of the line and port the same, I'd be inclined to at least keep the woofer the same, I'd imagine a TL that was tuned for a different driver would be a little bizarre sounding, wouldn't it?
Old 17th July 2011, 03:34 PM   #6
That is a concern of mine also, I have very little experience in this but I do dabble in audio engineering so I can trust my ears.. If it sounds wierd I will know straight away.
After all this is just an experiment..
However... I was wondering if there is some software that calculates the tuning maths?
And if there is, does it do TL designs?
Aaaargh so many questions.. I was hoping to just get the PDF and build the thing!
Old 17th July 2011, 03:56 PM   #7
DrDyna's Avatar
I'm pretty sure hornresp can do TL, but I'm the wrong guy to explain how, I can barely use it myself with lots of handholding, lol.
You may be able to put the driver you planned on using into hornresp and inputting the copied TL dimensions and see what's going to happen exactly.
Old 17th July 2011, 04:40 PM   #8
I do have to search if I still have the cabinet plans for the TB1 as pdf.
Old 17th July 2011, 07:08 PM   #9
frugal-phile(tm)
planet10's Avatar
THE TL modeling tool is Martin King's mathcad worksheets.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd July 2011, 06:34 PM   #10
Found them:
TB2A1.pdf
TB2.pdf
Clone of PMC DB1+ ??? Bigun Multi-Way 19 12th August 2011 12:30 AM
Pmc DB1i maartentje Multi-Way 6 31st March 2010 08:12 AM
PMC TL or QWT? Colin Full Range 18 10th April 2008 09:23 AM
Activate PMC DB1+ wiredcharlie Multi-Way 0 17th April 2006 05:31 PM
PMC Drivers lovitz Multi-Way 19 23rd October 2005 05:43 AM
Page generated in 0.10639 seconds (79.10% PHP - 20.90% MySQL) with 11 queries
