Old 15th July 2011, 10:21 AM   #1
Default TAD TM-1201 horn loading
Hi
I am thinking of horn loading my set of TAD TM-1201s in a front horn. Probably in a 150 Hz horn and then cross at about 250-300Hz.
Has anyone tried this or would it be better just to use it as a direct radiator?
Are there any commercial horns in that size that suits the TM-1201?
Many thanks,
Jeppe
Old 15th July 2011, 03:45 PM   #2
Default Contraindicated
Originally Posted by virious View Post
Hi
Many thanks,
Jeppe
A properly designed horn will provide a decade of usable bandwidth.
You will need a horn of comparable dimensions to provide loading down to a 2 meter wave length.
The primary purpose of such a horn, is to cover the speech range (200-2000 Hz) without bifurcation
There are very few manufacturers that provide, medium format, speech-range horns. Of these the following are notable:
Funktion One (Tony Andrews)
FUNKTION-ONE : OFFICIAL WEBSITE
Community Light & Sound (Bruce Howze)
Community Professional Loudspeakers
This JBL technical tech note may be of some help.
http://www.jblpro.com/catalog/suppor...pe=3&docid=201
Only in a listening space, a magnitude larger, will use of such a horn be beneficial.
WHG
Old 15th July 2011, 04:11 PM   #3
limono is offline limono  United States
You will find opinions here based on horn resp sims ,that TM 1201 is not really suitable for horn loading. Do a search on forums.
Old 18th July 2011, 10:54 AM   #4
Sorry for the late reply!
whgeiger: Could you post a direct link to the horn you think you be suitable as i'm not able to find it
limono: Could you also provide a link? I think i have read just about anything about the 1201, but not that its best used as a direct radiator.
Many thanks for your replys,
Jeppe
Old 19th July 2011, 03:18 AM   #5
If you want a speech range horn, to match the TD-1201 you will have to design it yourself.
This would be a non-trivial, although a possible exercise. I have already given you guidelines for doing that.
Parameters for this driver follow:
Nominal Impedance 8 Ohm.
Lowest Resonance Frequency (Fo)52 Hz.
Frequency Range 150-4500 Hz.
Rated Input Power 150 W.
Maximum Input Power 300 W.
Sound Pressure Level 100 dB/W (1m).
Total Magnetic Flux 324.000 Mx.
Magnetic Flux Density 14.500 G.
Recommended Bandpass Filter 200 - 3.000 Hz.
Recommended EnclosureOver 11 liter.
Effective Piston Diameter 260,0 mm.
Baffle Opening 276,0 mm.
Mounting Dimensions 293,0 mm.
Weight 11 kg.
Dimensions (diameter x depth) 318 x 110 mm.
Theile-Small Parameters
sd - Piston Area 0,0531 Sq M.
Revc - DV Voice Coil Resistance 5 Ohm.
Levc - Voice Coil Inductance 1kHz (mH) 0,68.
BL - Flux Density (TM) 26,0.
Vas - Equivalent Acoustic Volume (Liter) 63 liter.
Cms - Mechanical Suspension Compliance (x 10-4 m/N) 1561.
Mms - Mechanical Mass of Cone and Free Air Load6 g.
Mmd5 g.
Fs - Free Air Resonance Frequency 52 Hz.
Qms - Mechanical Q Factor1,43.
Qes - Electrical Q Factor0,15.
Qts - Total Q factor0,14.
Xmax - Max Linear Peak Excursion (O-P)2,5 mm.
Pmax - RMS Thermal power Limit300 W.
no - Relative Efficiency5,54 %.
Vd (cm²)1,33.
Max. Excursion Before Damage (P-P)22,
Run some simulations using Horn-Response to see where it takes you.
Horn throat Sd/2, length > c/(4*Fc), Mouth perimeter, = approx. c/Fc
Otherwise a simple sealed enclosure, with low-end equalization will do, unless your listening space is huge. Sensitivity of this driver is high.
As this is a low-Q driver, with limited xmax, c/o at >200 Hz.
WHG
P.S.
Here's the SPL plot from Horn-Response (McBean) with the TAD TM-1201 on a cosh horn.
Old 19th July 2011, 05:18 AM   #6
CLS is offline CLS  Taiwan
Mms - Mechanical Mass of Cone and Free Air Load 6 g.
Mmd 5 g.
The above, 5 or 6g, is wrong. It's from published datasheet I know, but it's wrong.
Times ten is more like it. And you'll have a much more declined FR.
Old 19th July 2011, 04:46 PM   #7
Default So What!
Qts and Fs are correct so the the typo has no effect!
WHG
Old 20th July 2011, 01:12 AM   #8
Have you built (of found) such a horn for this driver and given the combo a listen (or measure)?
Guess what? I have
Old 20th July 2011, 01:17 AM   #9
And that's a big beautiful failure. The biggest and most beautiful I have had.
Old 21st July 2011, 10:30 AM   #10
revintage's Avatar
Limono, you are so right. It wasn´t so long ago we discussed the subject here. This driver is not suited for horn use.
Brgds
Lars
TAD 1201 horn ? dede Multi-Way 40 20th September 2011 01:10 PM
WTB: TAD TM-1201 pengesluk Swap Meet 0 17th March 2011 03:49 PM
TAD TM-1201 wanted pengesluk Swap Meet 14 9th March 2011 03:14 PM
TAD TM-1201 and TM-1201H Wanted pengesluk Swap Meet 0 7th March 2011 02:32 PM
TAD TL-1102 vs TM-1201 or TM-1201H manp111 Multi-Way 14 3rd September 2010 09:23 AM
Page generated in 0.11249 seconds (80.23% PHP - 19.77% MySQL) with 11 queries
