| weltersys |
14th July 2011 06:11 PM |
Originally Posted by doug20
(Post 2639072)
It would be cool to see a DIY project with that 5" coax and a horn similar to what Danley offers with a coax driver in it.
The DSL SH-100 works well because the speaker's cone is an extension of the 8" co-ax HF horn, and the cabinet employs a larger horn continuing the same angle of the speaker cone. This gives horn loading over a fairly wide range, and raises the mid sensitivity closer to the HF horn sensitivity.
This 5" driver has a fairly low power 90 dB circular ribbon coming in at around 8K, horn loading the speaker would not increase the HF sensitivity, only the mid sensitivity.
Horn loading would give more mid headroom over a fairly limited band, but would require a complex crossover/compensation network, and the added mid headroom would allow one to play it at tweeter frying level, since the tweeter is only capable of around 103 dB at one meter.
EDIT: missed that the mid only handles 5 watts RMS/10 watts, horn loading it may allow it to keep up with the tweeter LOL.
10 watts into 90 dB sensitivity, a whopping 100 dB at one meter, 94 dB at two meters full tilt boogie.
I can sing louder than that.
