Old 14th July 2011, 10:23 AM   #1
Default diy center speaker
hi
i recently made a diy speakers (L +R). I now have from my old speakers 4 audax 8'' woofers and 2 morel tweeters. I am thinking to make a center channel speaker. I made some box calculation and the box must be at least 35l whitch is too much. The calculations is for 2 woofers. I wanna ask you if i can make a center channel speaker only using 1 woofer+one tweeter and not 2 woofers. Then i will have a box about 17l whitch is ok for my available space. I know that the problem is the big woofers but i don't have smaller ones.The speaker will be placed horizontally if that matters. For a center channel speaker what F3 i must have at least?
Old 14th July 2011, 12:33 PM   #2
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I have seen people use a center speaker that's exactly the same as their L/R speakers, but I'm not sure how well that works.
As far as F3, I'd say as low as you can get. I have a passive sub on my center channel and it sounds quite fat and nice.
Edit: Which Audax do you have? There's a design on this page:
http://www.hometheaterhifi.com/volum...er-9-2001.html
Old 21st July 2011, 07:53 PM   #3
boris81 is offline boris81  United States
If you plan on using active amplification you can make a smaller box and equalize the low end response to whatever curve you wish. (within limits)
Look up Linkwitz Transform.
Any DIY Speaker Builders in MD/DC/VA - Need $1000 DIY Speaker Recommedation Dkalsi Multi-Way 12 10th March 2011 12:48 AM
Need help with modification of DIY center speaker kjgarrison Multi-Way 10 24th September 2010 12:31 AM
1979 Janszen Z-600 panels for DIY center speaker? rkellyfitz Planars & Exotics 4 1st December 2009 03:12 PM
DIY Proac Center speaker purist Multi-Way 50 23rd August 2007 08:16 AM
DIY Center speaker using ScanSpeak??? vision Multi-Way 1 11th December 2001 03:33 AM
Page generated in 0.07032 seconds (70.59% PHP - 29.41% MySQL) with 10 queries
