Old 13th July 2011, 08:15 PM   #1
Default Glasses - a floor standing speakers.
Idea
Apple's design delight knows no bounds, even obsession translates into their own projects. That's how the idea came to "Glasses", another column in a minimalist style floor, simple shapes, smooth shiny surfaces, and I think successful combination of black and white. I wanted to refer to the design of other projects, " The Book of Sound "and" iPC ', which resulted in the use of the same type of material, Plexiglas. Anyway, here you go.
A little art
The columns are two-way, low-medium tone speaker that STX GDN-18-130-8-AKX , while the high tone is a Vifa DX25 , everything in the bass-reflex system in a simple box made ​​of MDF. The case is divided into three chambers, the upper empty the tweeter speaker, the center's largest bass and bass-reflex, and the lower the load in the form of sand. Everything is properly glued, twisted, suppressed and finally covered with a thin plexiglass. The material was bent on the heat with one lane of white and black cut two smaller pieces. At the end I put a couple of details in the form of portals to connect the cables and pins on which the entire structure stood. You are cordially invited to visit the gallery.
Photo!
Floor standing speaker project wanted! Johnnz Multi-Way 57 24th April 2010 06:49 AM
Floor standing speaker stand msjd4 Construction Tips 0 3rd January 2010 03:02 AM
tannoy 615 mk 11 floor standing speakers tricia Multi-Way 2 27th July 2009 05:38 PM
Floor standing cabinet for FE207e+FT17H ? nina Full Range 28 11th October 2007 09:29 AM
Leema Xaviers floor Standing Speakers lukecon Swap Meet 0 31st August 2005 03:02 PM
Page generated in 0.07353 seconds (69.39% PHP - 30.61% MySQL) with 11 queries
