Old 13th July 2011, 08:01 PM   #1
dirkwright's Avatar
Default Woofer waveguides?
I'm building a little 2 way with an 8" B&C woofer and one of their horn tweeters. The tweeter is considerably deeper than the woofer, so I want to offset mount them front to back such that their approximate acoustical centers line up vertically (aka "time align" the drivers). I cannot find much information on recessing the woofer into a short waveguide. I found this company doing it:
DESIGN - CONSTRUCTION
They claim it smooths the crossover transition.
Anyone have any opinions or information on this idea?
Old 13th July 2011, 08:50 PM   #2
johnB23 is offline johnB23  United States
Im assuming this is a sealed or ported box for the woofer, so any wave guide wouldnt really have an effect on the performance of the cabinet. The only way a waveguide would actually be effective for a woofer is if you used it in a tappedhorn configuration...but you said little some im guessing not ;D.
If you want to recess the woofer, just do so, it wont really matter much.
Old 13th July 2011, 10:56 PM   #3
Remember the woofer will have an acoustic delay because it's a lowpass system, partly mechanical and partly because Le in series with Re creates a first-order lowpass filter with its own phase lag. Merely aligning the voice coils isn't enough; most often the tweeter voice coil should be a few cm (an inch or two) behind the woofer voice coil.
Old 14th July 2011, 12:20 AM   #4
dirkwright's Avatar
Wow, I did not know that. thank you! So, I was estimating a difference of 2.5", but now it seems that it's a wash. I can mount both on the same board.
Geddes on Waveguides Variac Multi-Way 5665 24th April 2012 10:40 PM
Midrange Waveguides thadman Multi-Way 0 4th May 2008 11:33 PM
Waveguides ralphs99 Multi-Way 18 11th September 2006 06:56 PM
Page generated in 0.07577 seconds (74.02% PHP - 25.98% MySQL) with 10 queries
