Old 13th July 2011, 06:06 PM   #1
Frosteh is offline Frosteh  United States
Frosteh's Avatar
Default Baffle thickness - 3/4" or 1"
I'm building David Ralph's Chameleons (SB Acoustics 2-Way Title Page) and he uses 1" MDF for the baffles, but only 3/4" for the rest of the enclosure. I have enough 3/4" MDF left to make the baffles, but will it make a performance difference than using 1"? I have to buy 1" eventually for my subwoofer, but I don't want to have a large piece of unused 3/4" MDF laying around if I can avoid it.
Old 13th July 2011, 11:48 PM   #2
Brett's Avatar
3/4 will be fine unless the chassis of the driver is very thick and routing so it's flush will make the rest too thin to secure the driver well. In that case a small partial sheet of 6mm from a hardware store could be laminated onto it to get the required thickness for only a few $ and minimal wastage.
Old 14th July 2011, 01:50 AM   #3
David Gatti's Avatar
WHy not glue 2 pieces of 3/4" together for a 1 1/2" baffle?
Old 14th July 2011, 03:48 AM   #4
Do a 1 1/2 inch its solid and you can never have too much front stability
Old 14th July 2011, 04:13 AM   #5
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
You have options. You can add a brace to overcome any weakness you think the 3/4" mdf will have. I make mine out of hardwood. Thicker at the mid point, tapering slightly to each end
Old 14th July 2011, 05:16 AM   #6
Frosteh's Avatar
Just went and bought 1" MDF since I'll be making a subwoofer sometime anyway. Thanks for the help!
Old 14th July 2011, 05:18 AM   #7
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Do 1.5 inch , good stability and makes it easy for baffle offset ...
Old 22nd July 2011, 08:58 AM   #8
I laminated 2 x 18mm sheets for a 36mm baffle. Um, 36mm = 1.5".
Nice and solid, but I routed roundovers behind the woofers and midrange. Then I used t-nuts to hold the drivers in.
"Dipol 08" Baffle Dimension and List of Crossover Parts LineArray Full Range 37 3rd March 2012 11:09 AM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 06:07 PM
New Reference - SG-OB "Stargate Open Baffle" Magnetar Multi-Way 67 17th July 2008 07:04 AM
Need help using "Edge" to design Baffle Step Correction Circuit please. G Multi-Way 5 3rd July 2004 10:49 PM
Thickness of heatsink's "meat" Stabist Pass Labs 2 28th October 2002 06:33 PM
Page generated in 0.08838 seconds (76.10% PHP - 23.90% MySQL) with 10 queries
