Old 13th July 2011, 02:47 PM   #1
Default Cabinet vibrations
Is it a bad idea to position the mid satelite on top of the sub section ?
would the vibrations from the sub box beneath it cause unwanted vibrations that will be bad for listening ?
Old 13th July 2011, 03:53 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
It can be. The best solution is to make the sub nice and strong and heavy. You can use isolation between them but you'd have to make sure you get it tuned below the sub's operating band or you'll find your mains wobbling in tune with the subs.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 13th July 2011, 10:21 PM   #3
would it be better to incorporate the two cabinets into one ?
I could use spikes on the bottom of each sub and satellite as well .
Wilson puppies are done that way .
Old 22nd July 2011, 09:03 AM   #4
I posted somewhere here, that if you need to check if your woofers are causing vibration in other drivers, to put a multimeter across your drivers, then play some heavy bass.
If the drivers are being excited, you'll see a voltage. That's because the EMF in the driver will cause voltage to show. Can also be used to check for air pressure leaks between the bass chamber and the other drivers.
Old 22nd July 2011, 10:45 AM   #5
speaker dave's Avatar
How do you separate the effects of vibration from the fact that air pressure will also cross-talk to the other drivers? (A speaker is a microphone.)
David s.
Open Baffle Vibrations The Prof Multi-Way 58 21st August 2010 08:33 PM
Managing vibrations on audio equipments Eric Juaneda Everything Else 2 8th November 2008 07:41 AM
How do vibrations in a CD player/transport cause jitter ? percy Digital Source 18 7th April 2006 07:55 PM
The importance of proper setup and vibrations control Peter Daniel Everything Else 253 6th October 2003 03:57 AM
Testing cabinet vibrations Kanga Multi-Way 23 14th April 2003 09:29 AM
Page generated in 0.07213 seconds (75.57% PHP - 24.43% MySQL) with 10 queries
