Old 13th July 2011, 05:04 AM   #1
Default Audio Technology 10 inch woofer question
I am thinking of using an Audio Technology 10 " woofer with a 102 mm VC .
what is the max freq. I can use a driver such as this ?
Old 13th July 2011, 05:31 AM   #2
ScottG is offline ScottG  United States
10C77
-if it's like this one..
Yes, you'll likely need some form of correction for the peak in response, but it isn't a resonance (..the linear decay is clean).
The only real limitation technically is getting a good transition from "tweeter" (or mid) off-axis. Often larger waveguides are used for transitioning at lower (High) freq.s, with horizontal patterns more similar to the larger driver's upper freq. horizontal dispersion pattern.
Here is commercial design using a variation of this driver with their more typical mag. loaded poly cone:
Abbingdon Music Research - Product - LS - 77 Reference Class Monitor
It uses a waveguide loaded planar (..from SLS I believe). Thorsten could tell you more about it..
perspective is everything
Old 13th July 2011, 02:45 PM   #3
no its a 10 D 102 25 10 model
large Magnet and a 4 inch voice coil
ITs not a standard unit
Old 13th July 2011, 03:42 PM   #4
Currently I have a AT 10C as bass driver in my 3 way speakers. Its a VERY capable bass driver with good efficiency, fast and authoritative response. Its not great for mids. Although it outputs alot up in the midrange areas, it doesn´t sound good so I cut it sharply off around 150-200 Hz and up to avoid affecting the midrange.
The normal pp cone may perform better in the mids, but I would go for the 8" instead which also employs faraday rings for better midrange response.
domtweaker, what is your intended use for this driver?
-102mm VC is for more power capability but the increase in mm and LE means less frequency extension and lower SPL for the same magnet.
cheers,
Last edited by Juhleren; 13th July 2011 at 03:45 PM. Reason: Experiences on AT 10C
Woofer choices Audio Technology vs Focal Audiom domtweaker Multi-Way 12 3rd July 2011 01:48 PM
Can I run a 10 inch JL audio and a 12 inch JL audio off same amp ash4kel Car Audio 2 8th April 2011 02:12 AM
2way Studio monitor with 10 inch woofer help rhythmdiy Multi-Way 5 17th December 2008 12:56 PM
Wilson audio Sophia 10 inch which make? seems scanspeak 26w revelators? rhythmdiy Multi-Way 4 27th July 2008 06:30 PM
Snell replacement 10 inch woofer hollytone22 Multi-Way 5 26th March 2005 06:13 AM
Page generated in 0.08086 seconds (73.76% PHP - 26.24% MySQL) with 10 queries
