Can a crossover network rated at 8ohms be used with a speaker rated at 8 ohm? Thanks for your input
#2 |
That would generally be how it is done.. Not sure I understand your question though..
I will add that COTS cross-overs are quite generic and don't do a particularly good job with any driver - much better to get some help and have someone design you an X-O that is closely matched to the drivers and box design you are using.
www.kta-hifi.net |
#3 |
oh damn, my fault, can an 8 ohm crossover be used with 4ohm speakers. I am sorry for the confusion
#4 |
No, not unless you can tolerate an X-O frequency that will be much higher than expected. (With a simple 6dB per octave slope the X-O will an octave higher for example.)
www.kta-hifi.net |
#5 |
Yes, in the sense it will work in a fashion. no, in that it won't work well, but neither will an off the shelf "8 ohm" crossover work well with 8 ohm drivers for most applications, especially domestic hifi / AV. rgds, sreten. undefinition (see FAQs) Zaph|Audio FRD Consortium tools guide RJB Audio Projects Speaker Design Works HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs. DIY Loudspeaker Projects Troels Gravesen Humble Homemade Hifi Quarter Wavelength Loudspeaker Design The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs Linkwitz Lab - Loudspeaker Design Music and Design
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 13th July 2011 at 01:10 AM. |
| Crossover Question | ajh | Full Range | 10 | 21st September 2007 06:06 PM |
| do i REALLY need a crossover?? and an amp question. and an ohm question | legendaryfrog | Multi-Way | 4 | 29th October 2006 01:39 AM |
| Crossover Question | woody | Multi-Way | 3 | 26th January 2006 11:53 AM |
| Crossover question | Grahamt | Multi-Way | 5 | 5th August 2004 12:50 PM |
| Page generated in 0.07781 seconds (73.18% PHP - 26.82% MySQL) with 10 queries |
