First post
Hi all, I have 2 large home made speaker cabinets, and the tweeters have died - here are their technical specifications: KEF T27 SP1032 Tweeter Diameter : 10.8cm, 4.25in Weight: .64kg / 1.4lb Impedence: 8ohms Power Rating: 50 watts Programme, 8 watts continuous Frequency Range: 3,500 - 40,000hz Voice Coil Diamete: 1.95cm / .75in Recommended Dividing Frequency: 3,500hz Fundamental Resonance: 900hz I would like suggestions for a drop in replacement, I'm not particularly after quality here, I am after a lot of volume. I dont want it to do the audio equivalent of stink, but I have lots of quality elsewhere in the house. I'm sure you know what I mean. Something along these lines I was looking at - although £30 is almost too much -- what is your opinion on these? Peerless DT-105 / LR10DT 25mm dome tweeters PAIR NOS | eBay UK There will be a reward in the afterlife for good suggestions Thanks! |
#2 |
how does the quoted 89dB/W @ 1m compare to the 1032?
how does the 40W compare to the 1032?
regards Andrew T. |
| How to finde a replacement for a blown KEF tweeter | regiregi22 | Full Range | 5 | 13th April 2011 02:05 PM |
| KEF tweeter replacement | Robert Dunshee | Multi-Way | 1 | 23rd December 2008 04:24 PM |
| what tweeter to replace a Kef t27 | helios999 | Multi-Way | 1 | 16th June 2008 01:55 PM |
| drop-in REPLACEMENT for focal TC120Tdx2 tweeter | elves1111 | Multi-Way | 1 | 16th May 2008 05:07 AM |
| Audax ap210 with Kef t27 tweeter | fin1bxn | Multi-Way | 7 | 16th August 2007 07:49 PM |
| Page generated in 0.06346 seconds (71.83% PHP - 28.17% MySQL) with 10 queries |
