Old 11th July 2011, 05:40 PM   #1
dirkwright's Avatar
Default T/S for DE250?
The data sheet provided by B&C does not list all of the T/S parameters for this driver. Anyone have them?
In order to cross over at the recommended frequency of 1.6kHz, I need a notch filter(s). There are two resonance peaks for this driver, according to their data sheet. So I need at least: Fs, Qes, Qts, and Re. I sent an email to them on Friday but have not heard back yet. Maybe it's holiday in Italy or something. I'm sure they'll get back to me eventually.
Also, does the electrical impedance change when a driver is coupled to a horn? I bought the ME20 horn to go with this driver.
Old 11th July 2011, 07:52 PM   #2
dirkwright's Avatar
Here's the DE250 datasheet.
Old 11th July 2011, 08:29 PM   #3
speaker dave's Avatar
Electrical impedance diffinitely changes when you put a compression driver on a horn. This is part and parcel to the high efficiency making the horn loading a significant part, as opposed to the typical woofer where low efficiency means that air load is fairly insignificant.
Thiele Small figures for a compression driver? They aren't typically given since woofer box modeling doesn't apply. (The system is not well represented by 2nd order highpass analogies.) What were you trying to do with them? How do you kow what notch filters you might need without measuring the driver on the particular horn you will use it with?
David S.
Old 11th July 2011, 08:41 PM   #4
dirkwright's Avatar
David S.
Well, it looks like I have to measure it while mounted on the horn. Assuming there is still a resonance peak in the same region as shown in the datasheet, then I'm going to need a notch filter as I wrote about above. I need the T/S parameters to design the series notch filter. The formulas are:
C= 0.1592/(Re x Fs x Qes), L= (0.1592 x Qes x Re)/Fs, and R = Re + (Qes x Re)/Qms
Huh, just realized I need Qms. Dang.
Old 12th July 2011, 03:37 AM   #5
AllenB is offline AllenB  Australia
I was going to describe my DE250 (mounted) impedance but I'll just attach this screenshot. I have alternated between using two and three notch filters, two for the main peaks and one purely for the response at the peak of hearing frequencies.
I can't say it will be ideal to use formulas here. The frequencies are so close that they'll interact and you need to design them as a team, and then you'll probably want to play with them in tailoring your response.
Old 12th July 2011, 03:45 AM   #6
Then after using two filters (other components removed for this plot).
Old 12th July 2011, 12:23 PM   #7
dirkwright's Avatar
Thank you! Yeah, this looks difficult, for sure. I have WT2 and TrueRTA so I can do a decent analysis I hope. I don't want to go active on this little project because I have a sweet 50 watt stereo integrated amp that I want to keep. I'll go active on the 3 way horn loaded system I have planned.
Speaking of WT2, I also have a pair of ME10's mounted on DE10's for another project. So, I checked out the impedance plot and T/S parameters for this combination. They are different from the manufacturers spec, but only Fs is very different. I had emailed B&C asking for the Fs of the DE10 driver, and they replied with 1.7kHz, which is about where the peak is in their plot. So, I measured Fs of 2.5kHz with the ME10 horns installed and the driver sitting on my desk aimed at the ceiling. One thing I don't get is the inductance change. I measured 0.4mH, and the data sheet says 0.1mH. I didn't think the horn would effect the inductance of the voice coil. Do compression drivers have to broken in like woofers?
I can't test the DE250 + ME20 yet since they have not arrived.
Old 12th July 2011, 12:25 PM   #8
dirkwright's Avatar
It looks like the peaks shifted also. This is starting to feel like mud wrestling with a greased pig.
Old 12th July 2011, 12:50 PM   #9
It's not so bad when you get the hang of it!
I hope you don't think (as some misinformation would have you...) that an active system sidesteps dealing with driver issues, this would limit your success with active systems.
Compression drivers are a little different to dome tweeters. I cross mine over at 650Hz (first order).
They didn't shift, my filters grazed the sides of them. It was a juggling act. I can't remember whether that's the best I could do with common values or I have fudged them a little to mod the response since the last revision. I highly recommend a crossover simulator. For this part alone you'll want impedance magnitude and impedance phase for each driver.
Old 12th July 2011, 01:51 PM   #10
dirkwright's Avatar
OK, which crossover simulator do you recommend? I also have WinSpeakerz, which is fine for boxes, but doesn't simulate crossovers as far as I know. I can calculate the values no problem, but simulating them with an actual driver impedance curve is something I don't seem to have.
Yes, I was under the impression that active systems didn't care about driver impedance, resonances, etc. Can you suggest some reading for me on this?
B&c de250 CZ Eddie Swap Meet 3 12th August 2010 02:21 AM
2.5 way with DE250 / RCFH100 AudioGeek Multi-Way 4 22nd February 2009 09:48 PM
Polarity of B&C DE250? Horizons Multi-Way 0 31st October 2008 05:57 PM
B & C DE250 assembly Ed LaFontaine Multi-Way 3 18th August 2008 03:56 PM
DE250 and Horn combo tested here ttan98 Multi-Way 5 11th April 2008 02:12 AM
Page generated in 0.12403 seconds (83.52% PHP - 16.48% MySQL) with 11 queries
