Old 11th July 2011, 06:44 AM   #1
tunks14 is offline tunks14  United States
Default 2 way crossover help
So im confused..
I am in the process of designing a crossover for the new speakers I just bought.
I bought :
Dayton Audio DC28f-8 1-1/8" Silk Dome Tweeter
and
HiVi M5a 5" Aluminum/Magnesium Midbass Woofer
I was planning on the crossover point for these to be around 3500Khz. Could someone help me on how I would go about building a crossover at that point? This will be my first speaker build so this stuff is a little confusing at the moment. Also, how does one choose what order of crossover to use?
Any and all help/advice welcome.
Thanks,
Tunks
Old 11th July 2011, 09:19 AM   #2
pinkmouse's Avatar
Have you read This Thread yet?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 11th July 2011, 11:26 PM   #3
Because the Al cone has a peak at 5kHz, I'd consider crossing over lower, say 2KHz, the tweeter can handle this; for the same reason at least a 2nd order crossover - you may also need a notch filter at 5Khz to deal with the peak.
Here’s a design using the same woofer, no notch: http://ampslab.com/robin.htm
Zaph has tested this one: http://www.zaphaudio.com/5.5test/
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Crossover help DIFORCE Multi-Way 10 28th December 2009 05:29 PM
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Need Crossover Help Please. dshortt9 Multi-Way 2 24th November 2004 06:24 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.07141 seconds (75.19% PHP - 24.81% MySQL) with 10 queries
