Old 9th July 2011, 10:07 PM   #1
Default Is there a time delay between stereo speakers if...
....the amp is in one speaker (left) and the wire to the other speaker is 10 feet (right)?
Will it affect imaging? Other things?
Wire is 12 ga solid core twisted pair enamel coated wire. Amp 250w into 8ohm class D. Speakers are a DIY Geddes Nathan Clone.
Old 9th July 2011, 10:50 PM   #2
If I understand the question, you're asking if speaker cables are different lengths, will there be a time delay between channels? No, but it is possible that different lengths will make enough difference in R-C-L of cables that it might cause different sound from one channel to the other.
Mike
Old 9th July 2011, 10:54 PM   #3
CCU is offline CCU  Denmark
Send a message via MSN to CCU
The speed of electricity is almost as fast as the speed of light.. So it would take the signal to come from the left speaker to the right under one millisecond and i really don't think you would be able to hear that.
Plus. A lot of active speakers are sold as a pair, one active and one passive. If it was audible i don't think they would sell sets like that.
Old 9th July 2011, 11:54 PM   #4
tinitus is offline tinitus  Europe
you could use thin cable on the short length, and thick on the long one
nah, give the short one a little more, mount it, and forget about it
if you don't worry about it, you won't notice the possible small difference
Old 10th July 2011, 12:36 AM   #5
33 nanoseconds for 10 meters.
As was said, you'll get more phase shift at 20kHz from LCR effects.
Old 10th July 2011, 12:49 AM   #6
Or you could move the right speaker .00003 inches closer
Old 10th July 2011, 12:38 PM   #7
DrDyna is offline DrDyna  United States
DrDyna's Avatar
LOL, almost had my morning coffee come out of my nose.
Old 10th July 2011, 03:29 PM   #8
Ron E is offline Ron E  United States
Ron E's Avatar
Well, light travels about a billion (1,000,000,000) feet per second and signal in a wire travels somewhere in the range of 60-90% of the speed of light. About the smallest difference we could detect would be about 0.0001 seconds, so lets use 750,000,000 * 0.0001 = 75000 feet, so unless you have a 15 mile difference in wire length, I'd say ignore it.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 10th July 2011, 03:30 PM   #9
Loren42 is offline Loren42  United States
Actually, electricity propagates at about 12" per nanosecond, so 10 feet is about 10 nS.
If you use 1100 feet/sec for sound, then the difference is 0.00001 inches.
So, move them back 0.00002".
Old 10th July 2011, 03:44 PM   #10
Okay but I'm still a foot behind my time .0002 INCHES
B+ time delay relay cbutterworth Tubes / Valves 24 31st August 2011 12:53 PM
Time delay? fouchagalaga Everything Else 5 22nd May 2011 04:03 PM
time delay with 2 amps? thedman Solid State 2 2nd November 2007 12:22 PM
adjustable time delay back Analog Line Level 18 1st March 2006 08:01 AM
subwoofer time delay mart34 Subwoofers 14 15th August 2004 11:19 PM
Page generated in 0.09881 seconds (80.05% PHP - 19.95% MySQL) with 10 queries
