Old 9th July 2011, 03:17 PM   #1
dirkwright's Avatar
Default notch filters for vented boxes
I understand that notch filters are typically used when a high pass passive filter is used where the corner frequency is near the driver resonance. For woofers in vented boxes, there are two impedance resonances. I was wondering if using a notch filter on either or both of those, when no high pass filter is being used, would change the low frequency response of the loudspeaker. Would it improve the response, or do nothing? I can't seem to find any information on the web about this.
Old 9th July 2011, 03:47 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
A notch filter across the terminals will only modify impedance. For a perfect voltage source with zero output impedance, there will be no change at all.
This impedance modification is useful when crossing over near the notches, and also for reducing the slight bumps that can occur when the amplifier being used is load sensitive (high output impedance.)
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Cascaded Notch filters Blacknight Analog Line Level 0 5th June 2011 06:22 PM
Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters dtm1962 Multi-Way 10 8th February 2010 02:17 PM
Active notch filters neutron7 Full Range 2 19th November 2006 11:51 AM
Help on series notch filters. bowdown Multi-Way 1 9th March 2005 05:51 AM
Page generated in 0.06865 seconds (69.78% PHP - 30.22% MySQL) with 10 queries
