Old 9th July 2011, 02:40 PM   #1
Default WTMW Array Opinion
Does anyone have any experience with a WTMW alignment ??
X over points will be 150 /800/ 3800 hz
The bottom end bass is on the side of the cabinets WTMW on the front .
thank you to anyone who can shine any light on this topic
Old 9th July 2011, 11:42 PM   #2
AllenB is offline AllenB  Australia
Having two front woofers in that range will give you some control with floor/ceiling interactions.
Old 10th July 2011, 02:10 AM   #3
No Downsides though ?
I was told that using two mids will be a bad thing to do Are woofers different ?
Much less directional for sure compared to tweeters and mids .
There are some companies that even use two tweeters like the top of the line
Von Schweikert Two mids , two tweeters and a super tweeter in the center.
Old 10th July 2011, 02:34 AM   #4
What disadvantage with dual mids were you told about? Certainly they are harder to do without measurement. There is a benefit to be had with lobing around the crossover point, if that's something you want. About the woofers, they'd have to be large to be directional at 800Hz, notwithstanding the interaction between the two. If it were me, I'd do some drawing and modelling the distances to the floor/ceiling for each woofer and compare phase etc.
Old 10th July 2011, 04:33 AM   #5
I was told that MTM will not image as good as MT ?
Less Focus if MTM is used ? Therefore I am going to use One midrange only
Old 10th July 2011, 06:02 AM   #6
Moondog55's Avatar
Doesn't having 3 XO points mean you are designing a 3.5 way ??
Problems only if the M is too big, MTM works extremely well for me when 140mm or smaller is used.
My MTM using 205mm has a very small sweet spot.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 10th July 2011, 01:37 PM   #7
No I m doing a 4 way 15 , 2x10 , Mid , tweeter
Yes the small diam makes sense for sure .
The mids I am using are large magnets total around 180 mm ?
I think the single point source from the mid may work better though.
Old 10th July 2011, 02:04 PM   #8
tinitus is offline tinitus  Europe
electrically it could look like that
but should be considered a 4way if acoustic rolloff of the 10" matches that of the subwoofer
Old 10th July 2011, 02:13 PM   #9
depending on the mid, I would think twice about xo points
with 10" woofers, I would let them roll off by themselves, acousticly
and adjust the 15" rolloff accordingly
might be anywhere betweeen 50hz to 100hz, active
800hz seems a bit high for a 10"
but as said, depends on your mid
did miss which midrange driver ?
Old 10th July 2011, 03:04 PM   #10
they are Volt 2500 nice midbass units
Shorter MTM array or larger TM array? goldyrathore Multi-Way 4 30th November 2011 08:04 PM
Vertical WTMW driver alignment - pros and cons jb0194 Multi-Way 1 16th November 2008 09:20 PM
looking for opinion xxxwhezzy Car Audio 9 8th May 2008 03:53 PM
Want your opinion! vdi_nenna Pass Labs 9 16th January 2004 03:27 PM
I need your opinion.. Richard Moon Everything Else 1 11th January 2004 06:14 AM
Page generated in 0.10201 seconds (78.27% PHP - 21.73% MySQL) with 10 queries
