Hello all.
I'm thinking about design compact 3-way speaker with active filters. My goal is to achieve good bass perfomance and neutral detailed sound. For bass section wanna use Usher 8836A 7" midbass, crossed with Dayton RS52AN-8 2" dome around 800-1000 Hz. On top - Dayton RS52F-4 or RS28A-4 crossed 3-3.5 kHz. It will be closed box with Linkwitz transform circut. Calculations shows in 12 liter box (0.4 cu.f) with F3=50 Hz it can achieve 97 dB without violating Xmax. Normally I'm not listening loud so... What do you think? Any design built yet? Thanks. |
#2 |
My brother used the mid-range as a replacement for the dome in his phantoms, along with a foster planer tweeter and 2 4.5" arogel woofers in a PR box.
very satisfying. Remember, its all about compromise. I might have looked for a 8" or 10"woofer, since the Mid-range goes to 800 Hz, but it would be a bigger box ... Sounds like a plan. Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#3 |
Browsed Internet I'm inclined to use RS28F-4.
BTW how to edit my first post? |
#4 |
Editing only works for the first few minutes and then it gets disabled.
Your design idea will probably work but I don't understand the need for a 3-way. There are a few tweeters that can be crossed over low enough to match a 7" woofer. If I was in your situation I would probably use the Seas DXT tweeter and try to match it's dispersion characteristics to a 7" woofer as it was done by Mark K in his ER18DXT design. |
#5 |
stick to dome mid, you will not regret it
#6 |
with these drivers I'd choose ~500hz and ~1.5khz crossover points.
about your crossover points - 800-1000hz - that's where Usher 8836A cone starts to breakup(audible). With 3-3.5khz RS52F's humongous 18khz resonance still may get excited(perceived as clear crisp sound, detail). And RS28F will be pretty much idle, not using even third of it's potential. It's just my opinion. |
#7 | ||
For mid possible to use notch to block unwanted resonances. I choose RS28F because it's low distortion, mid priced and has mesh grille (child protection |
#8 |
http://www.humblehomemadehifi.com/do...20Box_copy.pdf
Hi, the above might be worth a look, with a more sensible box design, rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#10 | |
Maybe you can recomend the 7" driver with Fs below 35 Hz and small THD priced less $100/each? Thanks. |
| Bookshelf speakers | unknownuser200 | Multi-Way | 20 | 21st January 2012 06:09 PM |
| bookshelf | branet | Multi-Way | 5 | 27th June 2010 02:51 PM |
| My last bookshelf. | R-Carpenter | Multi-Way | 35 | 28th May 2008 11:53 AM |
| Efficient Bookshelf? | Whit | Multi-Way | 15 | 15th March 2007 01:26 PM |
| seas bookshelf | rv1890 | Multi-Way | 2 | 30th January 2006 10:24 AM |
| Page generated in 0.10503 seconds (79.10% PHP - 20.90% MySQL) with 10 queries |
