If one were to construct a 3-way design using a woofer rated @ 88db, would it be better chose a midrange with the same spl, or use a higher rated one than pad it down ? What if the mids spl's are say 2db lower than the woofers, does this generally lower the whole speakers efficiency ? Reason for the question's are most 4-5" inch mids generally are rated lower ect...
#2 | |
If the mids are 2dB lower, you may need to of them to keep up. Later, Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102 |
#3 |
Depending on the bass/mid c/o point and the baffle step frequency you can need the same for a low c/o point to needing a sensitivity for high point lower by the amount of BSC applied to the bass unit. Its all about how much and how you do BSC (baffle step correction.) rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
| Current efficiency of a SPL car | d3cibel | Car Audio | 1 | 30th June 2010 06:33 PM |
| Theoretical question concerning SPL /driver matching | p0lar | Multi-Way | 13 | 8th October 2008 10:11 PM |
| Testing Speaker Frequency and Efficiency(SPL) | John L | Multi-Way | 2 | 24th April 2008 10:59 PM |
| SPL Matching | duderduderini | Multi-Way | 2 | 7th August 2007 05:26 PM |
| Matching Efficiency | SMathews | Multi-Way | 9 | 22nd August 2004 10:28 PM |
| Page generated in 0.06630 seconds (71.98% PHP - 28.02% MySQL) with 10 queries |
