good evening,
I have disassembly my AR3a for repair and check the capacitors with my Beckman RCL Bridge. It's old model (1968), the crossover mount old Paper/Oil capacitor and when i measure it i read: single capacitor -> nominal 6uF measure = 7.3uF double capacitor-> nominal 50+150uF measure = 64+186 uF It's a good idea replace it or no? I'm very undecided......Please give me your opinion and suggestion thanks for all and sorry for my english |
#2 |
The paper in oil may be OK. They can sound good and sometimes not. If you want to try a polypropylene (for example) to see how it sounds, a value of 7u3 will show you the differences but 6u0 should produce the 'correct' result.
The other sounds as if it may be an electrolytic? If so, I'd replace that with a pair of new ones. |
#3 | |
You have a classic AR3a capacitor problem - drifted uF properties. When they drift, the original crossover target points also shift. Thus, the sound no longer is as the designers intended. Replace the 6 uf with a film cap. Dayton has 6.2 uF 1% caps & don't worry about the new voltage ratings. Replace the 50 and 150 with audio grade non-polar electrolytics. |
#4 |
Thanks at all,
I think my summer will be a working summer.... I try your suggestion and listen for best result bye Thermen |
#5 |
How is your result?
I did that but doesn't seem better than before,maybe worse. |
| ar3a aleph-x | tze-hao yen | Solid State | 0 | 22nd March 2010 03:45 AM |
| Capacitor Substitution | d5post | Parts | 7 | 3rd May 2009 12:59 PM |
| AR3a tweeter coils! | KJ2005 | Multi-Way | 0 | 12th December 2008 01:27 PM |
| AR3a | KJ2005 | Multi-Way | 4 | 28th September 2008 04:53 PM |
| Capacitor Substitution and my Junkbox BOZ | Arx | Pass Labs | 1 | 18th September 2003 01:29 PM |
