Old 6th July 2011, 03:16 PM   #1
Default Any suitable woofers for use without an inductor?
..Besides the Dynaco A25 or Seas A26RE4 (H1411). Anything 6" to 10" would be of interest, but would definitely prefer an 8". Must have a 2nd order roll-off, as close and smooth as possible, for an LR2 right around 2 KHz (-6 dB @ 2 KHz). Sensitivity must be above 90 dB @ 1W/1m, preferably 92-95 dB, as it'd be crossed to a dome in a waveguide with a single cap. Low to mid Qts is mandatory.. It'd be put in a small sealed enclosure for 0.5 to 0.7 Qts without any other high-pass filter, met below with multiple subwoofers with a digital LR2 low-pass, or possibly 1st order, depending (probably end up with different crossover points and slopes on the multiple subs).
I know this might seem picky and asking for too much, but that's the whole reason for this post, as I need help finding the right driver that meets this criteria (if one even exists). Oh, and to top it all off, low cost is priority, as there's a very good chance it'll end up being the heart of a large multi-channel system (9-11 channels, not including subwoofers).
Not really interested in discussion regarding why one should or shouldn't use this approach. It's something I've personally never tried before, but I see no reason why it couldn't work well if done carefully. Rather than searching for mids with good upper extension/high roll-off frequency (and the trade-offs that go along with that), and then trying to compensate and deal with the phase differences from that upper cut-off, only to add a huge inductor to the driver.. why not find the perfect driver and run it wide open?, then use a simple series 1st order electrical on the tweeter for a nice LR2 acoustic.
Meanwhile, the search continues..
Old 6th July 2011, 03:41 PM   #2
chlorofille's Avatar
Maybe Jantzen Audio JA8008 would fit the bill...
Sand till the end of time
Old 6th July 2011, 04:15 PM   #3
tinitus is offline tinitus  Europe
Originally Posted by BHTX View Post
...... but would definitely prefer an 8". Must have a 2nd order roll-off, as close and smooth as possible, for an LR2 right around 2 KHz (-6 dB @ 2 KHz).
it might work, with the right driver
but I doubt you will find any with 2khz roll off
and if it does, its probably a low sensitivity woofer with muffled midrange
the suggested Jantzen looks like a good suggestion
my guess is xo point around 4khz, but only a guess
but even without series indutor, you will still have phase issues to deal with
its still a 2way
I suggest to use 6db/12db, with zobel
then you will at least have some 'tools' for fine adjustments
having nothing to adjust actually makes it all much harder
but no harm in trying, sure thing
btw, please remember you also have to deal with BSC issues
one way be using two woofers
Old 6th July 2011, 04:34 PM   #4
Simple fact is your ignoring the baffle step and baffle step compensation.
No-one AFAIK makes a suitable driver regarding what would be your target
response function, and not a prayer at those sensitivities, c/o components
will be needed inevitably. For loud 1st order on tweeters is not good at all.
http://professional.celestion.com/pro/pdf/TF0818.pdf
Decent value, cheapish £30, no real bass, suits small boxes.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 6th July 2011, 06:36 PM   #5
http://www.monacor.de/produkte/lauts...artikelid=7376
Old 6th July 2011, 08:08 PM   #6
In case anyone has missed it, this is more along the lines of what I'm going for, except higher efficiency in an 8", and perhaps a slightly more accurate lowpass if at all possible.. https://www.madisound.com/store/prod...oducts_id=8638
It's my understanding that this sort of simple design was quite common a few decades ago. Still done in cheap systems out there today I'm sure, albeit very crudely.
Wouldn't work. Thanks though. Always kinda had a thing for that woofer. A bit pricey though.
its still a 2way
Agreed.
rgds, sreten.
This is what I was afraid of, and pretty much sums up my thoughts, at least until I started thinking about the Seas H1411, and then wondered if there was any possibility that something similar existed with a more sensitive 8".
In regards to the tweeter comment, what about those like the Morel CAT378/MDT37? Still no single cap?
https://www.madisound.com/store/manuals/CAT378.pdf
Hadn't quite forgotten about BSC. By the way, wouldn't there be a point where BSC wouldn't be an issue? About what size would the baffle need to be?
Oh well. Maybe I'll just go for a big pile of Behringer B2031P's instead.
Old 6th July 2011, 08:20 PM   #7
Pano is offline Pano  United States
Pano's Avatar
The Seas A26RE4 is the only one I know of that can do this easily, although you "might" gt away with it using a vintage Altec driver.
Why not the Seas? It's a good driver.
Take the Speaker Voltage Test!
Old 6th July 2011, 08:24 PM   #8
DrDyna is offline DrDyna  United States
DrDyna's Avatar
*rubs chin thoughtfully...*
I bet that would be a great woofer to use with the big Heil AMT using a minimalist crossover on the tweeter only.
Old 6th July 2011, 08:26 PM   #9
Pano,
Was just hoping for something a little smaller and a bit more sensitive with a lower price tag. Just curious as to whether or not anything else was out there, as I've never really seen anything like it. I guess I got my answer.
Old 6th July 2011, 08:29 PM   #10
Nice idea. Might make a great 2-channel setup. How does the AMT handle a 1st order though? I seem to recall coming across a lot of instances of people damaging them, along with the need and availability of questionable replacement diaphragms.
4 Pyle PPA 15 woofers (suitable for Open Baffle Bass) zobsky Swap Meet 1 17th December 2007 04:38 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
suitable dipole mid-woofers smak Multi-Way 21 4th January 2004 07:34 PM
Inductor for SOZ, is it suitable ? akira Pass Labs 3 30th January 2003 03:28 PM
Page generated in 0.13598 seconds (85.20% PHP - 14.80% MySQL) with 10 queries
