Old 6th July 2011, 04:17 AM   #1
Default Series woofers Bad idea or okay
Planning to run Two 4 ohm woofers in series
What I am I loosing
What I am I gaining
Old 6th July 2011, 04:30 AM   #2
wolf_teeth's Avatar
What I am I losing
What I am I gaining
No loss, except needing a larger cabinet for 2 drivers, and the cost of 2 over one.
Gain:
-more vertical directivity lobing in a vertical MTM.
-same sensitivity as one driver.
-more power handling over one driver, including halved Xmax for each the pair at the same output.
-easier impedance for a lot more amps, and easier to keep system impedance stable.
If you can afford it- what's not to like?
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 6th July 2011, 04:34 AM   #3
Imp is the issue here as a 2 ohm is hard to drive indeed .
So there is no dampening losses ??
Old 6th July 2011, 04:38 AM   #4
wolf_teeth's Avatar
So there is no damping losses ??
Your Qes damping will change, but it really is not a bad thing as a whole.
Later,
Wolf
Old 6th July 2011, 04:43 AM   #5
that means loss of speed correct ??
Old 6th July 2011, 04:49 AM   #6
wolf_teeth's Avatar
'Speed' is not a real seaker parameter, and no it does not.
Qes is the amount of electrical damping in the driver.
As long as the Bl curve, Qts, and Mms are corresponding to a well controlled driver, it's of no concern.
Later,
Wolf
Painting Heatsinks..I Know..Bad Idea valveitude Parts 30 9th March 2007 02:38 AM
Aleph30 with IRFP044's: Bad Idea? Dennis Hui Pass Labs 6 27th August 2003 08:00 AM
Is this a bad idea? Jimmy154 Multi-Way 3 24th November 2002 12:18 AM
Drivers in series - ok or bad? Circlotron Multi-Way 14 28th October 2002 04:15 AM
is this a bad idea? ChesterFuzzin' Multi-Way 2 28th June 2002 05:15 PM
Page generated in 0.07709 seconds (75.80% PHP - 24.20% MySQL) with 10 queries
