Impedance measurement clamp - URGENT - diyAudio
Old 20th August 2003, 10:22 AM   #1
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Default Impedance measurement clamp - URGENT
I'm building a clamp to hold drive units for impedance measurements today. The material at hand is mild-steel rectangular tubing.
I'm worried about the magnetic flux in the air gap being affected when the metal tube is in direct contact with the driver magnet assembley. Will this affect impedance measurements of the driver? i.e. do I need to use a non magnetic material to actually clamp the driver?
Old 20th August 2003, 11:15 AM   #2
Doug is offline Doug  Canada
Doug's Avatar
I use a Workmate opened up enough to mount the driver on its back firing upwards. I put a couple of rubber pads between the Workmate and the driver with just 2 small clamps ( one on each side of driver ) to keep it from vibrating, especially during resonance. I always get a nice clean impedance curve using the LMS system.
Works for me
Old 20th August 2003, 11:38 AM   #3
Doug's Avatar
PS:
The clamps I use are the plastic squeeze on types found at any build it center eg. Home Depot. I use various sizes depending on the size of the driver being tested.
In case you don't know what I mean by a Workmate in the UK I've attached a photo.
Old 20th August 2003, 11:47 AM   #4
Doug's Avatar
Here is a photo of the clamps I use.
Old 20th August 2003, 12:03 PM   #5
Vikash's Avatar
Hi Doug,
I've read several references that recommend measuring the driver in its natural position i.e. firing forwards.
Since I've got the materials and will probably be doing this a lot, I want to build a dedicated jig for driver measurement. It should have the ability to hold a driver 3' in the air, firing forward , and handle magnet assemblies up to 25cm diameter (my sub magnet is 20cm).
This is my idea:
Old 20th August 2003, 12:04 PM   #6
Vikash's Avatar
pic
Old 20th August 2003, 12:40 PM   #7
pinkmouse's Avatar
That looks very posh!
I use this...
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 20th August 2003, 01:09 PM   #8
Vikash's Avatar
Oh that's just me getting carried away as usual. My approach is to just go OTT and never have to worry about it again.
I think I'll settle for this inherently more sturdy design, and i won't have to worry about anything touching the magnet assembly either.
Old 20th August 2003, 01:21 PM   #9
-CGL- is offline -CGL-  Finland
Hi. Im using an engine vise and a large bench vise. Like the one in the link.
http://www.linearx.com/products/soft...p/EncShp05.htm
Mid page.
CL
Old 21st August 2003, 11:29 AM   #10
Doug's Avatar
Vikash;
I've made the impedance measurements with driver facing upwards and foreward but have not noticed any difference in the impedance plot.
Awesome looking designs you came up with though
Doug
Impedance measurement jig for SpeakerWorkshop Tenson Multi-Way 10 24th November 2007 11:56 PM
Impedance curve measurement bobsinclar Multi-Way 5 16th November 2006 01:17 PM
Impedance measurement Doug Everything Else 2 9th August 2003 05:50 AM
Having a problem with impedance measurement. prash Multi-Way 29 17th December 2002 05:24 AM
Vifa Impedance Measurement. Dave Multi-Way 27 2nd December 2001 02:55 AM
Copyright 1999-2017 diyAudio
