Could someone please model or simulate a series X-over for the Tang-band W4-1720 used with a SB Acoustics tweeter here is the data > http://www.solen.ca/pdf/sb/sb25stncc0004.pdf See also > http://www.parts-express.com/pdf/264-872s.pdf Any help would be greatly appreciated ! Thank-you for any or all efforts !
#2 | |
#3 |
Would the formulas in this pdf work for a ball-park series X-over ? Link > http://www.passdiy.com/pdf/CurrentSo...erNetworks.pdf
The amp I plan to use is a Pass F4 clone with a hi-gain SE tube preamp !
#4 |
You can get a "ballpark" crossover calculation from a tool like this:
2-Way Crossover Designer / Calculator It's not going to be flat with your drivers though, unless the drivers are razor flat and have the impedance curve of a resistor :S I've found success recently with learning how to use Speaker Workshop and either finding my driver's FRD/ZMA files online, or making my own with SPLTrace. I'm currently taking the time to learn how to use Speaker Workshop and all the FRD tools stuff and it's turning out to be a valuable skill. Give it a whirl! |
#5 |
The X-over calculator in your link does not do series x-overs, all though I believe Speaker Workshop will ! My problem is I do not have access to a computer that I can down-load anything into. I should have my own back up buy late September. Thank-you for the assistance !
#6 | |
#7 |
Is this forum not a collective of great works, designs and innovative people ? Come-on people, someone could surely run a simulation or two ! If nothing else it could turn into a really great thread ! Again any help would be greatly appreciated thanks !
#8 |
So I looked up the frequency response of that little woofer and it looks to me as though it can be used full range, as it's pretty much good up to 20khz.
Perhaps you can just hook it right up and save the tweeter for another project Edit: they say 8khz, probably because it gets a little bumpy from cone breakup. I'd model it for you, but it wouldn't be current drive. Last edited by DrDyna; 4th July 2011 at 04:41 PM. |
#9 |
If you could model it with the SB Acoustics tweeter that would be awesome ! Current drive is just on of the benefits of series X-overs ! I very much appreciate your efforts thus far thank-you !
#10 |
Eddited from post #7
| Tang Band W4-1757SB | aczern | Full Range | 11 | 12th December 2011 04:36 PM |
| Tang-Band W4-616 | chuck55 | Swap Meet | 1 | 3rd June 2010 03:43 AM |
| Anyone using Tang Band W4-1337? | ghetto | Multi-Way | 2 | 6th September 2007 03:14 AM |
| Tang-Band W4-1320SB - almost new | chuck55 | Swap Meet | 2 | 28th January 2006 01:35 PM |
| Anyone plan on trying the new Tang Band W4-1320SB? | mazeroth | Full Range | 1 | 7th September 2005 03:51 AM |
| Page generated in 0.11157 seconds (77.90% PHP - 22.10% MySQL) with 11 queries |
