Old 3rd July 2011, 02:38 PM   #1
Default 2426/2405 passive crossover
Hi everyone,
I just wanted to see if the ideas I have regarding a passive crossover for these drivers are okay...
Both are 8 Ohm drivers, but there is an efficiency difference between the two - the 2426 is 107dB and the 2405 is 105dB (from the JBL site anyway)
I am thinking I would like the crossover point to be around 10k or so, since without the 2405, the 2426 starts rolling off around there.
My main question is, do you think I can get away with just putting a crossover on the 2405 (a simple 2nd order L-R with 1uF / .25mH ), and just let the 2426 roll off naturally?
I am also thinking that the 2dB difference between the drivers may or may not be enough to hear, but if it is I imagine I could just put an L-Pad on the 2426 to knock it down a couple dB?
Thanks for any help or suggestions you may have
Byron
Old 4th July 2011, 08:02 PM   #2
I guess it's just not that interesting
b
Old 4th July 2011, 08:53 PM   #3
AllenB is offline AllenB  Australia
Perhaps 10kHz is not that interesting If it were me, I'd try without the 2405.
Old 4th July 2011, 10:42 PM   #4
Thanks, but the roll-off after ~10k is too much.
Byron
Old 5th July 2011, 01:41 AM   #5
Although there is more to a crossover, yes, you could cross it like that. The values you suggested may want tweaking after you listen or measure. The sensitivity difference doesn't sound like it would be a problem.
TLE-2426 as "negative" virtual ground? Steve Eddy Solid State 8 23rd June 2011 04:04 AM
JBL 2405 Alnico data revintage Multi-Way 2 2nd March 2011 09:54 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 12:14 AM
Jbl 2405/077 Slot Radiator Wanted macka Multi-Way 0 24th March 2003 07:23 AM
Page generated in 0.06529 seconds (82.34% PHP - 17.66% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
