Old 2nd July 2011, 09:01 AM   #1
Default Bass Cab Question
Hope someone can give me a bit of guidance here. I'm looking at building some horns for mids and top end for use at home, not PA, and i'm struggling with the bass enclosure.
I have a pair of TOA 15" drivers and i'm looking for a cab to put them in that will do frequencies below 2/300Hz. I'd like it to go as low as possible and being wife friendly isn't really an issue, but i'm restricted to size to some extent - max depth is 1m, width 75cm and heigh isn't really an issue (within reason)
Any ideas where i might get some plans?
Thanks in advance.
Stup'
Old 2nd July 2011, 09:48 AM   #2
Brett's Avatar
You need to find the T/S paprameters for the driver or designing for an LF alignment is a very hit and mainly miss proposition.
Once you have them, plug them into a similator program like Unibox and start modelling and asking more specific questions.
Old 2nd July 2011, 10:15 AM   #3
Hi, Need to know Fs, Qts and Vas of the driver to define the cabinet options, rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 2nd July 2011, 10:29 AM   #4
Thanks guys.
Fs - 40Hz
QTS - 0.26
Vas 180l
Sorry to be such a numptoid about this but i'm new to all this and want to get it right first time.
Old 2nd July 2011, 11:13 AM   #5
What you have are PA bass drivers, designed to go very loud in fairly
compact cabinets, around 50L tuned to 45Hz. What they cannot do
though is low bass, unless you use them sealed and apply bass boost.
Whatever you do F3 is around 100Hz, not good for domestic hifi.
rgds, sreten.
Old 2nd July 2011, 11:40 AM   #6
They were bought with a view to using them in an open baffle system, which is something i may well try with them.
Old 2nd July 2011, 01:35 PM   #7
norman bates's Avatar
open baffle, they will roll off at its mass corner = Fs/qts = about 160hz.
Don't run them open baffle.
Norman
Old 2nd July 2011, 01:44 PM   #8
Qts is far too low for open baffle, unless again you uses masses of boost.
Or current drive, i.e. an amplifier will high output impedance.
rgds, sreten.
Old 2nd July 2011, 01:50 PM   #9
chris661's Avatar
As a thought, the lowest string on a normal 4-string bass is 41Hz.
A 60L cab (per woofer) tuned to that frequency would give a slight bass shelf (how noticable that will be is debatable), but the lowest frequency the speaker is likely to see will be the one where excursion is minimal.
Add a steep low cut filter below that (most bass amps already have this built-in), and you're good to go.
If you're using a 5 (or 6) string bass, you may need to try different speakers with a lower Fs, in order to cover the lowest note (B0: 32Hz?) correctly.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 2nd July 2011, 02:12 PM   #10
E bay beckons perhaps?
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
Eden Bass Cab Question croat47 Instruments and Amps 8 26th March 2007 06:28 PM
Bass Cab wiring. Snoo Instruments and Amps 7 12th January 2006 05:28 PM
Help With Peavey Bass Cab eddie_the_ed Instruments and Amps 12 6th November 2005 09:02 PM
Bass Cab Help penguinbass1 Instruments and Amps 3 4th November 2005 07:27 PM
Page generated in 0.09784 seconds (78.82% PHP - 21.18% MySQL) with 11 queries
