Old 2nd July 2011, 05:05 AM   #1
otto88's Avatar
Default HiVi Planar Isodynamic Tweeters
Hi
Do or could be any of HiVi's Planar Isodynamic tweeters have open backs, i.e. dipole radiating? I know B&G’s Neo3 is, but 90.5 dB is a tad low in sensitivity for my application. I’m after at least 93 db from about 2000 Hz up.
The RT1II won’t cross below 3.5 Hz without losing sensitivity . .
The RT2E-A Overview RT2E-A Isodynamic Tweeter_HiVi, Inc. or RT8-II http://www.swanspeaker.com/product/htm/view.asp?id=18 could have their backs simply screwed off, but I can’t be certain if the backs contains the magnets . .
And would it lose sensitivity if the back were removed??
a system that won't go clean and loud is like a nice car that cannot go fast
Old 6th July 2011, 12:28 AM   #2
wolf_teeth's Avatar
The central magnet is attached to the rear-plate on the larger units.
Also- the screws once removed will likely force the voice coil to become unattached with a jig to hold them fast. It happened to me:
I would not advise it. Most will lose sensitivity if made to run dipolar anyway.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 6th July 2011, 02:24 AM   #3
otto88's Avatar
Default dipole HiVi
Thanks, Wolf
So I just bought *two pairs of HiVi RT8II.
They're slim, I'll run them back to back to give a dipole pattern like the mids (Neo10s) and rest of the system, and have about 94 db sensitivity.
I hope they sound as good as the Neo3 . .
Old 6th July 2011, 02:57 AM   #4
wolf_teeth's Avatar
The RT8 won't reach 20kHz, FYI. It's more suited as an upper-midrange.
You're welcome!
Later,
Wolf
Old 6th July 2011, 03:41 AM   #5
otto88's Avatar
According to HiVi's published FR, the RT8II is fairly flat up to about 10 kHz
have you tested it and found that it tapers off at . . . HZ?
Cheers
Old 6th July 2011, 04:10 AM   #6
wolf_teeth's Avatar
It wasn't me. It was somebody else on PE-TT forum, and I tried searching but can't find it. 10kHz is not 20 kHz, so that lacks quite a bit. And as I recall, it started to rolloff about 8kHz. It's very directional being so large, and the power response suffers off-axis. I tried PM'ing the person I think it was, and hopefully he'll right back and let me know where it was posted.
I hope to update later,
Wolf
Old 6th July 2011, 04:14 AM   #7
otto88's Avatar
PS: Your Photobucketed 61 Custom T-Bird is coool.
Is it road registered? can you see out?
Old 6th July 2011, 04:20 AM   #8
wolf_teeth's Avatar
It's actually not mine, but it is my driveway. The thing ran out of gas on the way to the Kruse Auction Park.
If you want t look it up on-line, it's called the 'Thunderflight', and the guy is a local around here. He was driving it, so it must be legal.
Later,
Wolf
Old 6th July 2011, 04:20 AM   #9
otto88's Avatar
Thanks Wolf
I cant hear much above 11 KHz, but as I already have the Neo3 (displaced as "tweeter choice" by the RT8II), I could use the Neo3 as more of a super tweeter
But I'd forgotten about the limited directionality of the RT8II, which is very large for basically a tweeter, 2 - 12 kHz . .
I'll do a frame that allows me to use either or both tweeters, and the Neo10 mid. See what works best
Old 6th July 2011, 04:24 AM   #10
wolf_teeth's Avatar
You're welcome-
Please report back your results!
I'd love to see the pics,
Wolf
Ribbon, Planar Tweeters for Sale IceBadger Swap Meet 1 30th December 2010 05:31 AM
Hivi B2S as tweeters? gainphile Multi-Way 10 28th February 2009 05:32 PM
FS: Vifa D25ASG and HiVi TN28 tweeters creek Swap Meet 0 9th January 2008 03:09 AM
4 Bg Neo3 Planar Tweeters omarmipi Swap Meet 3 28th September 2006 02:01 AM
FS: Hi-Vi Research RT2 Isodynamic planar tweeters bbaker6212 Swap Meet 9 25th September 2002 04:20 PM
Page generated in 0.10019 seconds (79.20% PHP - 20.80% MySQL) with 10 queries
