1" compression driver to horn mounting
Old 1st July 2011, 10:14 PM   #1
jdubs is offline jdubs  United States
Default 1" compression driver to horn mounting
Guys
I have Yorkville Unity horns that I want to pull out of the cabinets and use different tweeters with. The current BMS driver doesn't physically attach to the horn, but is instead held in place by a wood structure behind the horn.
Given I want to pull the horn out of the cabinet, how should I best attach a 1" compression driver to it? I was thinking of affixing (maybe some epoxy?) a 1/4" plate of aluminum with a 1" cuttout for the driver and two or three holes for mounting the driver.
Does this make sense? Maybe something like this already exists but my Google searches didn't turn up anything.
Thanks guys.
Jim
1" compression driver to horn mountingHide this!Advertise here!
Compression driver horn as "full range"? Racket Scientist Full Range 16 18th December 2010 08:44 PM
Compression driver without horn Sanon Multi-Way 4 7th September 2010 03:27 PM
Compression driver to horn adaptors Botte Multi-Way 4 9th April 2010 02:11 AM
Why does a compression driver need a horn? Defo Multi-Way 39 6th January 2010 03:18 PM
Compression driver /horn < 1000hz - ?cheap 1.4"? fb Multi-Way 29 7th July 2009 05:47 PM
