I am planning to build pair of speakers for my brother in law this weekend and wanted to use what I had on hand. I have a pair of the Dayton RS125-8 and a pair of Vifa XT25sc50-4 ring radiators. I found this project, the Microbes, here: Microbe The tweeter used is the Tang Band T25-1166s, a 4 ohm neo driver that appears to be very similar on paper to the Vifa XT25sc50-40. Basically I wanted to substitute the Vifa for the TB and wanted to know if I would be able to do so without much modification to the XO. Can someone offer some suggestions or advice on doing this? At first glance it appears the Vifa is a tad more sensitive (91.6 vs 90) but beyond that Qts is very similar (0.9 vs 0.87)....maybe a little more padding of the tweeter is all that is needed? Thanks for your input in advance! Jeff |
#2 |
I'm by no means an expert, as I just recently started trying to hone my skills designing proper crossovers, but it looks to me like it wouldn't be too much of an issue if their fs is similar, otherwise you may have to tweak with the parallel resistor on the tweeter.
#3 |
Fs is very similar, one is 837hz (Vifa) and the other about 920hz (TB).....since the vifa will reach a little lower I would think it would be fine at this XO point (somewhere around 3000hz as I recall)...
#4 |
It's worth a shot, anyway. In any case, the changes are going to be relatively small, the resistors will change slightly and the cap might change a little as well.
If you have speaker workshop, the designer of the microbe has posted the workshop file on the microbe site, you might want to snag it. I looked around but I couldn't find FRD/ZMA files for your new tweeter, perhaps someone here has it. If they do, snag the workshop file, snag the FRD for the new tweeter and stick it in there instead of his existing tweeter and see what the sim looks like. Edit: I wonder if that tweeter is the same as my TG30-04 but with a different face. Last edited by DrDyna; 1st July 2011 at 06:51 PM. |
#5 |
I tinkered with the design provided on the microbe page with the frd/zma I have for the XT25 I've got, which is slightly different from yours, so your mileage may vary, but this is what I got.
I'm still new at this, so if anyone wants to audit this...feel free! |
#6 |
I'm not sure where it's posted, but I bet it's on Roman's site....
'evilskillit' on PE's board built a pair of them. Later, Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102 |
#7 |
On your schematic above you have the 3.3 and 6.8 caps in series...are you sure this is correct?
#8 | |
Technically, there should be another coil across the tweeter to make it a 2nd order crossover. You're right, it's probably incorrect, but she looks flat, right? Edit: Again with less deleting Last edited by DrDyna; 1st July 2011 at 09:42 PM. |
#9 |
No the XT25TG30 is an entirely different beast....mine is neodymium the TG30 is not....
But thanks anyway, I see what you're talking about. |
| Swap: Fostex T825 for a higher efficiency top tweeter by Fostex, Coral etc | anubisgrau | Swap Meet | 0 | 1st May 2011 02:58 AM |
| tweeter swap out?? | stuman | Multi-Way | 4 | 3rd June 2009 07:42 PM |
| OpAmp Swap? | edge4syn | Tubes / Valves | 8 | 9th February 2009 01:30 PM |
| What to swap a 6AV6 for? | Hugsy | Tubes / Valves | 2 | 1st September 2008 05:14 AM |
| want to swap some tubes | briand | Swap Meet | 1 | 9th June 2003 12:59 AM |
| Page generated in 0.10181 seconds (77.66% PHP - 22.34% MySQL) with 11 queries |
