Old 19th August 2003, 04:39 PM   #1
e96mlo is offline e96mlo  Sweden
Default Distortion in loudspeaker transducers
Does anyone know where to obtain any good information on the subject?
Since a lot of people go through lots of trouble to get really low distortion in power amplifiers, why not do the same with the speakers?
Where should I start my search?
/Marcus
Old 19th August 2003, 04:53 PM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
You must have read my mind...I dunno if you follow Lynn Olson. I do ...he can make something seem so easy.
Anyway Lynn has this thing about DHT triodes having very low intrinsic or inherent distortion. (Without feedback)...before I was never into distortion specs...who cares? I mean j-fets have low distortion but honestly who would use them for creating a musical illusion?
Let's just say Lynn changed my mind on this..and now I've been thinking of speakers....in the same way you have...
Now I have read about line array's or multiple drivers for a given frequency range having very low distortion as well. Because of the amount of drivers. So reading up on line arrays could be handy.
http://www.audiodiycentral.com/resource/pdf/nflawp.pdf
Secondly the distortion in the enclosures that the drivers are mounted is just as important? Here a dipole comes to mind...i.e. no-box, no colouration...(obviously an exageration)
Bas
Old 19th August 2003, 05:14 PM   #3
Vikash is offline Vikash  United Kingdom
Vikash's Avatar
Types of distortion thread
Old 19th August 2003, 05:38 PM   #4
SL probably has the best treatment of distortion analysis that I've seen so far. He does a pretty exhaustive look at distortion in both woofers and mids when selecting the drivers for the Orion (and Phoenix for that matter)
http://www.linkwitzlab.com
Old 19th August 2003, 06:44 PM   #5
If you have access to the Journal of the Audio Engineering Society, a good place to start could be
Mills P.G.L. , Hawksford M.O. Transconductance Power Amplifier System for Current-Driven Loudspeakers. Journal of the Audio Engineering Society,
Vol. 37, 1989, no. 10, p. 809-822
and all the references they quote. Searching this forum for Mills and Hawksford could also give some useful info.
Old 19th August 2003, 07:03 PM   #6
Thank you all for the great answers!
I realize that minimizing distortion in speakers will be more expensive than doing so in amplifiers. Or (for the horn-solution) require a bigger living room =)
/Marcus
Old 19th August 2003, 10:23 PM   #7
Hi Marcus,
Minimizing distortion does not have to be expensive. On the other hand it need not lead to good sound!? The converse is true as well. Horn's have a lot of distortion...but they sound good apparently...........go figure.
Bas
Old 19th August 2003, 10:47 PM   #8
Brett's Avatar
Nope, properly designed they have very low THD, IMD and FMD with the IMD esp being much lower than direct radiators.
Manufacturer specs for my compression drivers is <0.5% THD at 114dB.
Old 19th August 2003, 11:17 PM   #9
Hi Brett,
Guess I have read to many "hi-fi" mags in my life..although I stopped around 10 years ago...I must have read a couple of times that horns --ie front loaded horns had massive distortion..!!!!
But I did some reading on the net...
http://www.ossaudio.com/hornbackgrounder.htm
And found out that someone must be lying!
Bas
Transducers lpoht Multi-Way 8 14th May 2007 12:19 AM
FPS transducers - what to do with them? Spasticteapot Planars & Exotics 14 6th December 2006 11:40 PM
Drivers/loudspeaker distortion .. i want to know the truth!! JinMTVT Multi-Way 84 19th December 2004 07:38 PM
loudspeaker distortion test sites dvdwmth Multi-Way 1 18th December 2004 12:48 AM
Tactile Transducers seangoesbonk Parts 2 3rd July 2002 12:13 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
