Old 29th June 2011, 01:45 PM   #1
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Default Eton 7-360 Hex and my potentially terrible idea.
I've had a couple of these Eton 7-360 Hex drivers for a while. I was doing some reading online while I was trying to come up with a proper cabinet.
I've got them in a 2 way with a Seas 25TAF/G.
Now, here's the part where I think I might be losing my mind.
From the looks of the response of the Eton (unfortunately, I don't have any proper measuring equipment) it rolls itself off pretty sharply starting around 4500hz or so and I thought to myself...I wonder what the drawbacks would be to running the midbass unit naked and crossoverless and using a simple 6db slope on the tweeter in various places until it sounded like it was mating up properly, essentially ending up with a crossover that consisted of 1 capacitor.
Has anyone ever done anything like this with one of these woofers?
Old 29th June 2011, 02:30 PM   #2
DrDyna's Avatar
Scratch that, 2 parts. Had to put a resistor on the tweeter, it's a little happier than the woofer is. 4.7uF and 2ohms (so far).
Old 29th June 2011, 03:30 PM   #3
jerome69's Avatar
I have the FRD/ZMA file of the Eton 360 but it seems to be in a box.
For the 25TAF H0398, a little old this tweeter, but the K27G, soft dome should work in the simulation ?
You have an horrible peak near 4500Hz with the eton, you need a notch to suppress it.
File attached. You can use speaker workshop or pcd.
Have fun !
Old 29th June 2011, 03:46 PM   #4
DrDyna's Avatar
Have fun !
Thank you sir
It actually sounds surprisingly good right now, I've been listening to it for about an hour. I can tell that there are a couple of peaks, so I might play with it, but i like the idea of "lol, what crossover?"
Old 29th June 2011, 03:58 PM   #5
jerome69's Avatar
What crossover ?
I played with the data, you can do a crossover very closed to the latest HiVi-ViFa.
Old 29th June 2011, 04:09 PM   #6
DrDyna's Avatar
What crossover ?
Which I still haven't ordered the parts for yet It's on my shopping list next time I've got some spare cash though
Old 29th June 2011, 05:15 PM   #7
DrDyna's Avatar
One thing is for certain, I like this midbass unit a lot more than the HiVi m6a in my other set. You say the crossover would be very close to the one you helped me with for the HiVi/Vifa, would it change much if I were to use these midbass units instead of the HiVi?
Could I just leave out your notch filter and be fine?
Old 29th June 2011, 05:58 PM   #8
DrDyna's Avatar
Have fun !
For some reason when I try to open that FRD it doesn't do anything, I still have just one straight line for frequency response
Edit: It's working in Speaker Workshop, gonna try to figure this out.
Old 29th June 2011, 06:43 PM   #9
jerome69's Avatar
You mean open with pcd ? The first line of the file is a header, you should remove it. About the data, don't forget to add for the woofer, the acoustic center (I use -4cm).
The peak is 4.5kHz, the notch is different 0.47mH 2.2uF R~5ohms.
See the schema. I calculate very fast. You can do other slopes it's up to you
Old 29th June 2011, 06:58 PM   #10
DrDyna's Avatar
It's going to take me a while to get used to Speaker Workshop. For some reason, PCD won't load the frd or zma files. I tried removing the first line also. It's probably office 2010, I need to install an old one on another computer.
Eton woofer 8-480/32 HEX gormish123 Multi-Way 1 23rd February 2011 01:59 AM
Eton 5-880 Hex 24 Dickduff Swap Meet 6 15th October 2008 08:08 PM
Eton 12-680/62 Hex mach.88 Swap Meet 2 7th May 2007 12:17 AM
Eton 11-581/50 HEX AuroraB Multi-Way 7 7th September 2004 02:57 PM
Eton 32 Hex woofers Jimmy154 Multi-Way 8 12th February 2004 10:34 AM
Page generated in 0.09597 seconds (83.48% PHP - 16.52% MySQL) with 11 queries
