Old 29th June 2011, 10:14 AM   #1
rvrazvan's Avatar
Default Monacor compression drivers. 160hz-7000hz!!!?
No matter what, i'm going to buy this driver. It's very cheap and for this price there is nothing in this price range that can go that low.
Here is the user manual.
http://www.partysound.ro/manuals/KU-516.pdf
I'm planning to build the horns myself. But i need some opinions on this one.
Where to cross-over, what type of horn profile to use? I'm not to good with Hornresp .
Old 29th June 2011, 10:27 AM   #2
Thes are intended for things like
http://www.top-info.ch/Antik/thumbs/608.jpg
But maybe they would be nice drivers for a talk-box.
Charles
Old 29th June 2011, 10:41 AM   #3
rvrazvan's Avatar
yeah i know. Not hi-fi-ish....but I don't worry to much about sound quality as i will have only a few watts to power them.
Old 30th June 2011, 11:41 AM   #4
rvrazvan's Avatar
up!
some help :-D
Old 30th June 2011, 01:01 PM   #5
Pano is offline Pano  United States
Pano's Avatar
Figure out how big a horn mouth you can fit into your space and go from there. A 160HZ front loaded horn will be big!
Old 30th June 2011, 02:15 PM   #6
revintage's Avatar
Hi r,
You can forget about using it up to 7k, possibly up to 3-4kHz max. JMLC recommended it but only from 200Hz up 1,2k. So a 150Hz Tractrix might be a good choice as it only will be 65*65cm.
A 200Hz l´Cleach is close to 100cm dia.
Brgds
Lars
Old 2nd July 2011, 10:31 AM   #7
rvrazvan's Avatar
hmmm. only 65*65 cm. that's nice for 150 hz. Where should i cross the compression driver?
Old 2nd July 2011, 11:32 AM   #8
revintage's Avatar
Up or down?
Brgds
Lars
Old 2nd July 2011, 01:49 PM   #9
rvrazvan's Avatar
down. the other end is not that important for now...
how is this enclosure called(the LF enclosure). It looks like a good addition to the mid-horn. But i have no clue about the science behind it.
Old 2nd July 2011, 03:30 PM   #10
revintage's Avatar
200Hz or just below will be OK.
Did you forget to add a picture?
Brgds
Lars
160Hz Bump Diggar Full Range 5 6th September 2010 04:22 PM
need advice about Monacor drivers steph_tsf Multi-Way 10 24th May 2010 11:17 PM
Compression drivers or cone drivers - what do you prefer? Defo Multi-Way 25 28th February 2010 10:57 PM
Compression ratio and diaphragm size in compression drivers inkasound Multi-Way 50 8th January 2009 03:38 PM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 02:42 AM
Page generated in 0.10361 seconds (76.75% PHP - 23.25% MySQL) with 11 queries
