Old 27th June 2011, 11:10 PM   #1
jdubs is offline jdubs  United States
Default Plans for a mid-bass tractrix horn?
Guys, I want to pursue something like this:
Bass cabinets
But I need better plans. Is there anything else out there like it? Seems pretty ideal for blending with my Unity horns at ~300hz....and it goes down low (enough - 45-50hz).
Thanks!
Jim
Old 28th June 2011, 12:30 AM   #2
Dual 15 PPSL is probably your best be to match up with a Unity Horn as it will provide uniform dispersion between the sub and the horn.
moray james
Old 28th June 2011, 01:53 AM   #3
Moray, can the dual 15 PPSL run up high enough (300hz or so), frequency-wise, though - and if so, does it sound good that high?
Thanks for the idea.
-Jim
Old 28th June 2011, 02:03 AM   #4
The PPSL should be able to reach up to 300Hz, but it really depends on the drivers and the geometry of the cabinet's slot.
I don't think I agree with the above statement that the dispersion is necessarily going to match between the two sections.
Old 28th June 2011, 04:09 PM   #5
Guys, given my application, what would be the recommended PPSL design and 15" driver complement?
Thanks,
Jim
Old 28th June 2011, 05:01 PM   #6
fmena is offline fmena  Canada
Default 80 Hz midbass horn?
See link for 80Hz midbass horn (click sidebar link for diy 80 Hz midbass horn)
inlowsound.com
Hope this helps
Cheers
FM
Cheers
FM
Old 28th June 2011, 05:59 PM   #7
Thanks,
Jim
Don't limit your selection to just 15in drivers.
Do a search here (and audio asylum) for PPSL and DJK.
Old 28th June 2011, 07:24 PM   #8
Expo 15 since this is what you were asking for I think.
Info on how to blend a PPSL woofer with a Unity Horn about as good as it gets.
William Cowan's Homepage look under heading of Unity Horn. Best regards Moray James.
moray james
Old 29th June 2011, 04:50 AM   #9
Brett's Avatar
Sounds terrific, but it's not push pull.
Old 29th June 2011, 05:13 PM   #10
Guys, I like Eminence drivers...how about plans for 15" Eminence Kappa PPSL? I've done a LOT of searching and can't find actual plans for such cabinets.
Thanks,
Jim
JBL 2226J Mid bass horn - need help doug20 Multi-Way 60 1st June 2011 06:32 AM
Mid-bass horn (easy to build) carpenter Multi-Way 66 26th April 2011 07:27 PM
looking for help with find plans for Tractrix Horn to suite Lowthers ken mead Full Range 2 20th September 2009 02:09 AM
Manifold mid bass horn entry??? fredos Subwoofers 0 28th October 2008 09:32 PM
Tempest Bass horn plans weikertball Subwoofers 6 20th September 2008 05:29 PM
Page generated in 0.09439 seconds (79.97% PHP - 20.03% MySQL) with 10 queries
