#11 |
Probably not, but there's no magic to it. Just a two driver ported pox, either 4th or 6th order, and the manifold as small as is practical.
#12 | |
PPSL is a way of confguring two drivers in order to achieve some reduction in distortion (two drivers inside a plenum facing back to front). That is all it is. You will still need to decide whether you want a ported cabinet or a vented cabinet. There might even be a horn loaded configuration. PPSL can be done with either. If you want a store-bought version that you could copy, there was one made by Electrovoice Again, do a search here and elsewhere with the terms: PPSL, DJK Last edited by WithTarragon; 29th June 2011 at 07:15 PM. Reason: .... |
#13 |
Guys, I decided to try 2 Rythmik servo 12"ers per side in a push-pull open baffle setup. Will report back how this goes.
-Jim |
| JBL 2226J Mid bass horn - need help | doug20 | Multi-Way | 61 | 10th October 2012 11:19 AM |
| Mid-bass horn (easy to build) | carpenter | Multi-Way | 67 | 14th July 2012 03:09 PM |
| looking for help with find plans for Tractrix Horn to suite Lowthers | ken mead | Full Range | 2 | 20th September 2009 02:09 AM |
| Manifold mid bass horn entry??? | fredos | Subwoofers | 0 | 28th October 2008 09:32 PM |
| Tempest Bass horn plans | weikertball | Subwoofers | 6 | 20th September 2008 05:29 PM |
