Im looking for a 6.5" midwoofer with decent efficiency for a 2-way in sealed cab with subwoofer. I was contemplating the 18 Sound 6ND430 until I saw the frequency response from Zaph's tests:
Zaph|Audio
The efficiency drops very quickly from 200hz down. Am I right to assume that after BSC efficiency will be in the low 80's?
The Tang Band W6-1721 on the same page looks like it will achieve much better sensitivity (due to the 100-200hz hump negating need for BSC) with higher xmax, lower Fs. Its also about half the cost of the 6ND430.
Am I looking at this correctly? Is the TB a better choice here?
Zaph|Audio
Zaph|Audio
The 18Sound is more of a midrange than a woofer, BUT if crossed over to a sub high enough (130-150hz) it should retain it's efficiency. A sealed box is tough here and with BSC, let's say 1/2 then we're talking 89-90db efficiency. You want higher efficiency, look 8" or larger pro woofer or multiple 6.5"s. No real sealed box bass performance from any of these until 12" but.......
Id be happy with 89db of sensitivity, however won't I have some pretty severe localisation issues with the sub at 150hz crossover? Sub will not be sitting between the speakers.
Got burnt spending lots of money on a very well regarded B&C 10inch woofer and feel hesitant to try anything bigger than 6.5". I want to ensure I get a clean midrange at the expense of some efficiency.
Hi Sreten,
I did notice that, though oddly enough, the eighteen sound data sheet shows the 16ohm with higher efficiency compared to the 8ohm datasheet:
6ND430 - LF Neodymium Driver
The PDF on that page shows a graph for the 16ohm with a higher sensitivity in the frequency response over 100-200hz.
022066N430-6ND430-16.pdf
If you are very sensitive in the range 100-500, go to a 8" ! A 7" is not very at ease in this range.
http://www.eighteensound.com/staticContent/applications/kits/18Sound_kit8.pdf
SPH-135/AD - Monacor hiFi bass-midrange speaker 60Wmax 8Ω - Europe Audio
maybe something like this? worth a look perhaps
6.5" is the max for me unfortunately. Ive heard VERY good response from a 5" in this range so im sure it can be done.
Looks nice but has a similar drop in efficiency at the 100hz point (much like the 6ND430) . Probably not suited 2.1 way
Ok not larger than 6.5" but read this : 5 July 2011
If you want a good sound, not to be disappointed, buy a hi end driver ? Don't hesitate to pay a good quality ? scan-speak, seas, accuton, audio technology, Focal etc.
SEAS seems to me the best price quality ratio. They have a large panel of 6.5". The excel driver sounds very good, you will be not disappointed. Don't waist your time with SB or Tangbang, the price is lower but the quality is not as good.
The 6N430 is a good driver for midrange if you do not want to pay more.
- Need help with midwoofer choice for 2-way
