Old 24th June 2011, 07:58 PM   #1
Default Damping of the speaker cabinet
I am building my bookshelf now. My cabinet is made of birch plywood but with the traditional rectangular shape so I think it need some damping.
But after some experiments I feel it sounds best without damping. I have some questions now
If I would like do the damping from small which surface of the internal cabinet I should try first? Is it the back surface of the drivers? Thanks !
Old 24th June 2011, 08:03 PM   #2
Loren42 is offline Loren42  United States
The back is probably the most critical.
Old 24th June 2011, 10:36 PM   #3
Well, it depends what you mean by "damping".
Some folks use this term to mean stuffing the cabinet (to absorb back waves, or make the cabinet volume "seem" larger). Others use the term for a treatment applied to the cabinet walls (or bracing) in order to reduce cabinet vibration.
These two issues require different techniques. What is it that you are trying to cure?
Old 24th June 2011, 10:52 PM   #4
There is only one way to know, and that is to measure with a mic in order to see if standing waves are causing their typical patterns on the frequency response. Then, if there are such standing waves, calculate which dimension in the enclosure corresponds to them, and dampen those surfaces first.
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall.
cabinet damping thoughts... stephenmarklay Multi-Way 8 7th January 2010 02:53 AM
JX92S - cabinet damping affecting midrange? AntM Full Range 0 10th December 2009 11:51 AM
Cabinet Damping patherb Multi-Way 11 12th July 2008 12:54 AM
Cabinet Damping pjpoes Multi-Way 17 13th April 2007 08:06 PM
internal cabinet damping gloop jives11 Multi-Way 6 5th July 2006 09:29 PM
Page generated in 0.07051 seconds (72.01% PHP - 27.99% MySQL) with 10 queries
