just looking for a simple answer to a question i have floating around my head
will i do damage or is it ok to experiment with weird / random connections of passive x overs and drivers? lets use this as an example DIAMOND 2 WAY STEREO PASSIVE SUBWOOFER CROSSOVER S @NEW | eBay 1. if i connect both sets of subwoofer outputs to a single subwoofer (svc) what results would i expect? (x over point/ final ohms/load amp would see? 2. if i connect both sets of speaker output/s to 1 speaker same question (im guessing id get a stereo signal through the single speaker)? will i do damage or is it ok to experiment with weird / random connections of x overs and drivers? |
#2 |
Hi 60ndown,
Connecting the two outputs to a single speaker would effectively short the outputs of the stereo amp driving this, at some frequencies. In the case of the single sub, it would be at low frequencies where the only load between the channels of the amp would be the DC resistance of the inductors themselves. This puts the amp at risk. |
#3 |
As Allen said, you'd be shorting the amplifier outputs together if you did that. Probably not a good idea to try. Depending on the amplifier topology, you could have serious issues.
I remember an old Adcom GFA-1 cube I had about 15 years ago, because they strapped amplifiers together to get the rated output, even shorting the grounds together could prove fatal and in my case did just that. There's nothing like the smell of roasted silicon in the morning. |
#4 |
thanks fellas !
i didnt know that but it makes perfect sense. ill save my amp from almost certain destruction |
| deliberately unmatching output tubes | porl | Tubes / Valves | 17 | 15th January 2010 11:28 PM |
| Anyone deliberately dial in 2nd harmonic? | DrewP | Tubes / Valves | 24 | 19th November 2009 01:06 AM |
| Buzz goes the GC but may have placed componets incorrectly. | AJ Bertelson | Chip Amps | 1 | 4th January 2006 04:10 AM |
| connecting a passive sub | andrewkl | Subwoofers | 1 | 27th February 2005 02:52 PM |
| connecting speakers | rs1026 | Multi-Way | 2 | 4th August 2004 03:30 PM |
| Page generated in 0.06874 seconds (73.79% PHP - 26.21% MySQL) with 10 queries |
