Old 23rd June 2011, 12:12 PM   #1
Default SB_acoustics_by_me
I have designed enclosure for SB17NRXC35-8 and SB25STC-C000-4 it is ML-TL 1.25/2.5 with 120cm length, and tuned approximately to 36Hz, but does not have knowledge how to design crossover, so could someone design crossover for me. The enclosure is from factory data not measured
Old 23rd June 2011, 01:11 PM   #2
jerome69's Avatar
All is already done, just make a choice
http://www.zaphaudio.com/DLR/
Old 23rd June 2011, 01:14 PM   #3
I saw that but I like to make something on my one if I can
Old 23rd June 2011, 01:15 PM   #4
dlr is offline dlr  United States
I can show you some crossover options for the original, but discontinued SB25, not the SB25STCN that you want to use. Still, it may help with the woofer section of the crossover. You won't be able to directly use the tweeter crossover, but it may give you some help with doing your own.
The Chameleons
Dave
Looks like I posted right after Jerome. The point about the tweeter, though, is important. I'm not sure that a direct replacement would work, at least not optimally.
Old 23rd June 2011, 01:19 PM   #5
jerome69's Avatar
Why do you ask for help ?
Old 23rd June 2011, 01:23 PM   #6
DrDyna is offline DrDyna  United States
DrDyna's Avatar
SB Acoustics 2-Way Title Page
That page has 4 different designs to choose from, I'd probably go with one of those, they look pretty straightforward.
Old 23rd June 2011, 01:26 PM   #7
Crossovers I have a little problem with them not sufficient knowledge (most important),no measuring equipment for frd etc…
Old 23rd June 2011, 01:31 PM   #8
Comparing the manufacturer data sheets for the suggested tweeter and the old one I used, there will be some difference in response with the same crossover. The new, smaller SB has a higher Fs with a different raw highpass response, so it will have some difference around the crossover area. I can't vouch for how well it will suit. It may be close enough, but the only way to be sure would be to test.
Dave
Old 23rd June 2011, 01:33 PM   #9
Thanks for link it seems my quest is ended
Old 23rd June 2011, 01:35 PM   #10
jerome69's Avatar
The job has been done in the right way, nothing to do more.
But if you read the article, he gives the PCD file. You can do your own crossover.
SB Acoustics 2-Way : Crossover Software
It is your own ball game.
Page generated in 0.10766 seconds (81.81% PHP - 18.19% MySQL) with 10 queries
