Old 22nd June 2011, 02:12 PM   #1
Default Advice on modifying bookshelf speakers
I have a pair of grundig M8C bookshelf speakers that I got for free that I plan on using as monitor speakers my home studio that I'm (slowly) setting up. Currently I'm monitoring on a pair of pioneer bookshelf speakers, but I need somthing better (read: flatter freqency response).
Currently the grundigs have the input wired straight across the woffer(5" 40w) then through two 10uf electrolytic caps back to back and across the cone tweeter(2" 15w), which is mounted on a plastic frame that allows it to be swivled left and up, centered or right and down, and then across a small pizeo disk that doesnt seem to do much(sticking a finger across it does nothing audible to the sound, even when listning to white noise)
The woofer encolsure is constructed from 9mm mdf and is 208mm deep * 169mm wide * 356mm high internal. The woffer cabinet has a port in it which is 43mm diamiter at the open end and is 103mm deep. I can't mesure the diamiter of the inside of the port.
My first thoughts were,
-Replace pizeo plate with a 1" dome.
-Stuff some fibreglass into the woffer enclosure.
-Glue that F****** annoying peice of plastic that supports the 2" still. (It rattles.)
-Bi/Tri amp the whole setup.
-Possibly replace the 2" cone with a 2" dome.
So that is what I am planning so far, can anyone else add any suggestions? (Bearing in mind that I'm after flattest freqency response over anything else, that the speakers will rarely be pushed, and that I will be sitting in one postion in front of them all the time.)
Old 22nd June 2011, 11:49 PM   #2
AllenB is offline AllenB  Australia
I would consider replacing the 2" and the piezo with a single driver.
Old 23rd June 2011, 12:07 AM   #3
So put a 1" tweeter where the 2" is now and biamp?
bookshelf speaker project advice milen007 Multi-Way 42 8th November 2008 04:13 AM
Bookshelf fullrange advice wanted Rocky Full Range 56 26th June 2006 02:10 PM
Need advice on modifying my Diva Swan M200's owdi Multi-Way 0 22nd November 2003 06:01 PM
Modifying Crossover Advice BigMacX Multi-Way 2 6th August 2002 08:49 AM
Page generated in 0.07573 seconds (72.03% PHP - 27.97% MySQL) with 10 queries
