Old 21st June 2011, 03:14 PM   #1
matevana's Avatar
Default Help with parallel notch filter
Getting some conflicting information from various online calculators. I have a simple peak I'm looking to tame at 630 Hz. It is 6dB strong, and about 3dB strong on either side at 500Hz and 800Hz respectively. Beyond that it is basically flat.
I'd love to come up with some consistant inductor, capacitor and resistor values as a starting point. Can anyone help?
Old 21st June 2011, 03:26 PM   #2
Jay is offline Jay  Indonesia
May be it is conflicting because it is not sure which one is parallel and which one is series?
Are you talking about the notch filter which is in parallel with the driver?
Old 21st June 2011, 03:31 PM   #3
matevana's Avatar
I believe it is called a parallel notch because the three components are connected in parallel. It is however in series with the driver. I think a series notch filter is typically used to tame a resonance around the drivers Fs point. The parallel notch can be designed to tame any peak in a drivers operating range.
Old 21st June 2011, 04:21 PM   #4
Okay, I understand. I have checked the internet, indeed one site has erroneous calculator. This one attached is okay (but it is theoretical). In practice it is a bit different
Old 21st June 2011, 05:50 PM   #5
matevana's Avatar
Thank you! I did see that calculator but was concerned that the formula may have been off. Is there a preference as to whether the notch filter go between the driver and crossover, or crossover and amp?
Old 21st June 2011, 08:22 PM   #6
John Bsuch's Avatar
Default Another great source
http://www.mh-audio.nl/spk_calc.asp#newqts
Old 23rd June 2011, 01:28 AM   #7
It depends on the real crossover: what drivers are affected at 630Hz? If this peak is on total response, and there are more than one driver producing this frequency signal, then you have to put between amp and xover if you expect a theoretical (symmetrical) notch.
In a 3-way, at 630Hz usually 2 drivers are in effect so you cannot put the filter on the woofer or midrange alone.
Old 23rd June 2011, 02:16 AM   #8
AllenB is offline AllenB  Australia
matevana, you cannot put the filter between the amp and crossover for your needs. The filter requires source impedance to work (something in series before it). Putting a notch filter before the crossover has another purpose and is useful for modifying the impedance to make the speaker easier for the amp to drive, but this is often not done.
Old 23rd June 2011, 01:26 PM   #9
matevana's Avatar
This is a simple 2 way design crossed at 2k Hz. Since the peak occurs at 630 Hz, I am assuming its all coming from the woofer rather than the system. I gather then the notch filter should go between the crossover and the woofer?
Old 23rd June 2011, 01:47 PM   #10
That should work.
I am wondering where this would be coming from. Have you investigated the possibility of floor bounce?
Parallel or serial notch filter in a crossover? Jonasa Multi-Way 12 3rd May 2012 10:54 PM
Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters dtm1962 Multi-Way 10 8th February 2010 02:17 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Contradicting Parallel Notch Filter from Various Sites. ]|[ GorE Full Range 3 11th March 2005 03:48 AM
parallel notch filter help kan3 Multi-Way 2 23rd January 2004 03:20 AM
Page generated in 0.09494 seconds (78.45% PHP - 21.55% MySQL) with 11 queries
