Old 21st June 2011, 02:12 AM   #1
wsnnwa is offline wsnnwa  United States
Default Question Amp+Speakers
So I have a weird situation and I do not know much about how this will work out if I go ahead and do what I plan on doing.
I own two GEMINI GSM-3622, each has two 18" speakers at 16ohm and 250watts RMS and they are connected in parallel thus bringing the ohm down to 8 once it goes to the amp. Well on each of them one of those speakers died, leaving me with only one speaker on each. I got two replacements(peavey 1801 black widow) from an uncle of mine the ones I got are the same size 18" but they are 8ohms, and at 350watts RMS. So this means that once I put them in to replace the old ones and connect them in parallel the ohm would be 5.333. I will be connecting the pair to a new Behringer EP4000, 2 x 2,000 Watts into 2 Ohms; 2 x 1,400 Watts into 4 Ohms; 4,000 Watts into 4 Ohms (bridge mode).
Would everything be fine? Should I instead put the two peavey 1801 black widow's together in one box and the other two that have the same specs in their own? To keep one at 4 ohms and the other at 8 ohms, would these be better on the amp and speakers than what I had originally planned.
B&W speakers,custom CNC enclosure speakers,radial horns felixx Vendor's Bazaar 0 6th April 2011 08:15 AM
In ear canal phones vs Around the Ear Speakers amp question haroldo_psf Chip Amps 1 21st September 2009 11:16 AM
Stupid Question: Sub Amp Out to Front Speakers? BlueWizard Multi-Way 4 13th January 2009 12:30 AM
4-ohm Speakers on 6-ohm Amp? (newbie question) diesel_88 Multi-Way 23 25th October 2007 08:54 AM
Multi-room audio system (speakers & Amp question) dwalter Multi-Way 0 17th November 2004 07:22 PM
Page generated in 0.06128 seconds (66.36% PHP - 33.64% MySQL) with 10 queries
