Old 20th June 2011, 06:27 PM   #1
ching0n is offline ching0n  United States
Default 2 way mini bookshelf w/bose fullrange and HiVi tn28
So I had a pair of the pictured pioneers laying around and was disappointed with the performance in the lower frequencies. I thought I could improve on it and make a good set for a SET tube amp. I chose the bose full range driver based on the TS parameters found at parts express. The problem I'm having however is that the sound is horribly shrill between 2-4khz. I have not installed a low pass filter since I'm awaiting the tweeters; however the crossover point for the high pass (lowest recommended being 1800hz) is going to leave a big gap in that range.
I opted to get genuine bose drivers (from a car) since they were way cheap and didn't have to wait (unlike P-E). Perhaps the characteristics of the bose are worse than the P-E replacements?
Parts Express Parts Express Replacement Speaker Driver for Bose 901 4-1/2" 1 Ohm : Questions, Answers, How To, FAQs, Tips, Advice, Answers, Buying Guide
Old 20th June 2011, 06:43 PM   #2
kevinkr's Avatar
May need a shallow notch between 2 - 4kHz to make these sound right..
Do this with a parallel LRC network in series with the "full range driver."
Edit: Bose makes a lot of different 4" drivers, not sure that you can safely assume that the car drivers are anything like the ones being sold by Parts Express. Variants I am aware of include ones with 1,2,4, and 8 ohm voice coils, with and without magnetic shunts, different cone material formulations, and different spiders.
www.kta-hifi.net
Old 20th June 2011, 07:00 PM   #3
this is a 1 ohm driver w/a cloth surround (unlike the foam surround of the 901's and PE's). Paper cone w/o doping (unlike the 151's)
I've heard of impedance mismatch affecting tone (although I am not sure how); my test amp is a ss rated to run 4-16 ohm loads. I figure since the drivers are relatively efficient and am only cracking the vol. 1/4 of the way, it wouldn't hurt anything.
Old 20th June 2011, 07:03 PM   #4
frugal-phile(tm)
planet10's Avatar
I have 2 pair of those Pioneers. I didn't listen to them much stock, but EnABLed they sound fine. You are never going to get much bass out of a 3" driver.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st June 2011, 11:16 PM   #5
I've tried two different crossovers (left overs from something) and did see an improvement. Granted these are not sized for the application.
One was a car crossover (what looks like a 2nd order Linkwitz-Riley)...I think it was sized for 4 ohm loads; 2x10uF caps, a big ceramic resistor and two identical inductors of unknown value.
The other one came from a home speaker, looks like a 2nd order xover....10&12uF caps, different sized inductors sharing a single ferrite core and big resistor like the other one.
The 1st one had less bass than the 2nd one, but the 2nd one's bass was too boomy. I guess i'll salvage the car xovers' circuit boards to fit my application; but I'm still affraid of the tweeter's Fo being so close to the xover point. Any advice?
I was initially hoping to just have a high pass filter (cap on tweeter) and that's it.
Old 21st June 2011, 11:56 PM   #6
regardless of any other problems, how are you going to drive the driver, at 1 ohm, volts and amps are the same value!!! Surely, these drive units were meant to be used in multiples?
Old 22nd June 2011, 12:38 AM   #7
yes, parallel array of 9 I think. I've gotta read up on impedance mismatch I reckon, but my luxman seems to be doing ok....should I stop before I burn something?
Old 22nd June 2011, 02:19 AM   #8
Thanks; for posterity:
Car Audio - Parallel Notch Filter Circuit for Speaker Design
Now i just need to take some frequency response measurements. Any recommendations for quick and dirty freeware?
Old 22nd June 2011, 02:33 AM   #9
just another
wintermute's Avatar
I'd definitely recommend holmimpulse!
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 22nd June 2011, 05:32 AM   #10
Tony.
can you use any run of the mill microphone? I'm having a hard time finding calibration procedures for something other than certain units.
HiVi B3S in mini transmission-line DocLorren Full Range 55 25th September 2009 07:08 AM
FS: Vifa D25ASG and HiVi TN28 tweeters creek Swap Meet 0 9th January 2008 03:09 AM
Bookshelf fullrange advice wanted Rocky Full Range 56 26th June 2006 02:10 PM
8 - 8 inch Silver Flute and 8 TN28 HIVI jadenlinkletter Multi-Way 5 27th January 2005 02:58 AM
Page generated in 0.11891 seconds (82.89% PHP - 17.11% MySQL) with 11 queries
