I just picked up a pair of Celestion Ditton 66. I believe they are a late model 1 with the veneered front. One speaker is putting roughly half the top end while the other sounds great. What capacitor on the crossover does the duty for the tweeter?
Thanks! |
#2 |
frugal-phile(tm)
Pull out the drivers and put a multimeter across them. Or even just (low level) output from your hifi.
If you are lucky it will be an XO component. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I measured the tweeters. They are both around 4.4ohms.
#4 |
frugal-phile(tm)
Do they play music (direct connection)? If yes, time to look at the crossovers.
From a posting on the forum: ![]() dave dave
#5 |
Looks like a recapping is in order. I might just unload these and let the next owner get them in order.
#6 |
Check the L-Pad. That or a driver are more likely to fail than a cap.
#7 |
I don't see an L Pad in there. That would be an adjustable resistor?
#8 |
Swapped the tweeters and discovered it is faulty. The search begins.
#9 |
Anyone have a Celestion HF2000 tweeter and maybe a midrange unit voice coil?
| Celestion Ditton 66 | peterdav | Multi-Way | 33 | 21st March 2012 03:53 PM |
| ditton 66 vs ditton 662 | loves speakers | Multi-Way | 0 | 22nd May 2011 09:09 PM |
| Celestion ditton 66 | KenP | Multi-Way | 10 | 24th November 2003 06:08 PM |
| Page generated in 0.09135 seconds (72.76% PHP - 27.24% MySQL) with 10 queries |
